Wind noise from the A Pillar area
Old Oct 15, 2018 | 08:22 AM
M. Stojanovic's Avatar
Default Wind noise from the A Pillar area
I have a wind noise from the area of the A Pillar or the wing mirror (difficult to tell which one) at speeds above about 60 mph, getting stronger with higher speeds. Overall, not too bad but I would like to get rid of it or reduce it, if possible. So far, I have done the following:
1. New genuine Jaguar door seal
2. Installed the tape at the wing mirror gap as advised by TSB 501-32 (Wind Noise Door Mirrors Repair Procedure) - no change
3. Tested with masking tape over: the drip molding to roof gap, the windscreen seal along the A pillar and over the top corner, the door to A pillar gap and along the top of the door, the step between the door glass up the A pillar and along the top and along the vertical gap between the door and the front wing; nothing made any change.
I now tend to think that the wing mirror itself is just producing the wind sound. Is it "normal" for the X308's to have some wind sound generated by the wing mirrors or is there anything else I can try?
Old Oct 16, 2018 | 11:32 AM
nilanium's Avatar
I've noticed some sound from there as well, usually becoming noticeable above 75mph. I figured it was due to the car's shape and the shaping of those rain gutters around the A-pillar causing turbulence.
You could try driving with the mirrors folded in (when traffic is low) and see if that affects the noise?
Old Oct 17, 2018 | 09:57 AM
I have tried with a tape over the gutter, no change. I have tried with different positions of the wing mirror glass (moving it by the control knob), no change. I have also tried with completely folded mirror - some change in the type of sound but the basic wind noise remained unchanged. As you said, it is probably just the shape of the body and the wing mirror (I thought a Daimler Super V8 would not have this kind of "discomfort"). I am going to try one more thing - tape around the small gap/step between the wing mirror housing and the chrome (in my case) trim attached to it.
Old Oct 17, 2018 | 01:55 PM
Highhorse's Avatar
Here's an old post of a X300 on mirror noise.... https://www.jaguarforums.com/forum/x...d-noise-60843/
Old Oct 21, 2018 | 12:58 AM
I finally found out what was causing the wind noise from the A-Pillar area on my car. As I mentioned before, I installed a new genuine door seal. What I found out was that the new seal, being fresh and "biting", was catching on the A-Pillar drip molding when closing the door and, instead of the seal sitting fully in, it was folding outwards (I noticed that the door needed a bit more force to close but I thought it was the new rubber needing some time to bed-in). I then applied silicone lubricant on the rubber and the underside of the drip molding and could see that the seal could then slide in properly - no more wind noise.
I will also try to gently knock the chrome trim of the drip channel along the A-Pillar and see if it will move slightly more away from the door seal to prevent the rubber folding back again. I can see that the drip chrome molding at the A-Pillar, on the side in question, is somewhat closer to the door frame then on the other side, even though the door is aligned perfectly.
Old Oct 21, 2018 | 03:30 AM
Stu 1986's Avatar
I feel your pain, although you have sorted it now. I've noticed a "buzz" has developed on my car and I'm convinced it's coming from inside the driver's door mirror or the door panel. It's driving me bonkers because there aren't any noises elsewhere on the car! Small noises can cause big issues! LOL
Old Oct 21, 2018 | 08:55 AM
I also have a very high pitch "buzz" (a bit like a mosquito) but it starts only at speeds over 115 mph so I am not really concerned about it (how long can you keep 120 mph). Not clear where it is coming from, somewhere from the front. It is not the windscreen wiper as I have already tried wit the wiper removed. My test after the successful rectification of the sitting of the door seal along the A-Pillar did not include 120 mph so the "mosquito" might also be gone (I'll check it out later).
Old Jun 26, 2024 | 04:49 AM
Oliver94's Avatar
This comes from the top of the windshield where the two windscreen trims meet in the middle. There is a small gap which makes that sound over roughly 100mph.
Press on the windscreen from the inside outwards and the noise goes away immediately.
Old Jun 26, 2024 | 08:19 AM
So, the small gap acts as a whistle at certain air flow. Interesting, thanks for the info. I just sold my Daimler Super V8 but others who experience the sound will know where it is coming from and think of a solution which could be just seal the gap with some silicone.
Old Jun 26, 2024 | 11:09 AM
RandyS's Avatar
I would not expect to find many Jaguars in Malaysia and especially the
Daimler version. I hope the new owner is as meticulous as you.
Old Jun 26, 2024 | 02:46 PM
vincent661983's Avatar
why not , Malaysia is RHD and so is Daimler version of our X308.
Kief
Sep 20, 2016 10:52 AM
Unhingd
Sep 14, 2016 09:10 AM
jaglover922
Jan 11, 2014 12:04 PM
XJcat
Dec 27, 2011 08:15 AM
locorebob
Jul 17, 2011 08:17 AM
