XJ8 poor idle/shuddering
Old Aug 3, 2015 | 11:45 AM
jwindwood's Avatar
Default XJ8 poor idle/shuddering
Guys
Just picked up a 1998 XJ8 3.2- it's a lovely car and was the right price with pretty much full service history and LPG conversion.
Driving it today, I notice only one significant problem. When the engine is at idle, or when slowing down to just before idle, the car seems to shudder. It doesn't stall, but just shakes a bit at idle-it's a really odd sensation.
It drives absolutely fine, smooth gearchanges and no stalling or warning lights.
It does the same on either LPG or petrol so I'm pretty sure it's not a fuelling issue.
Any ideas as to what the problem might be? It's not been serviced for over a year so I was going to do that as a matter of course.
Many thanks for your advice.
Old Aug 3, 2015 | 07:58 PM
sparkenzap's Avatar
CEL? Codes?
Old Aug 4, 2015 | 01:00 AM
jwindwood's Avatar
Originally Posted by sparkenzap
CEL? Codes?
Sorry-I'm new to all this. I assume you mean fault codes, which I intended to get checked after servicing, but what's CEL ?
Thanks.
Old Aug 4, 2015 | 01:39 AM
JagV8's Avatar
Same as proper name - MIL.
Get an OBD tool - one with live data - and look at fuel trims as you may well have an air leak.
Old Aug 4, 2015 | 01:01 PM
jwindwood's Avatar
This kind of thing?
Car Scanner EOBD OBD2 OBDII Diagnostic Data Live Code Reader Check Engine Scan | eBay
Old Aug 4, 2015 | 01:33 PM
jwindwood's Avatar
Right. Just realised what you mean-no, no check engine light or any other warning lights visible. All normal whilst moving but rough idle. A friend has suggested it might be a coil failing-would this appear on a scan?
Old Aug 5, 2015 | 04:30 AM
JagV8's Avatar
Maybe. I'd stop guessing and look at live data. Very cheap to do.
Old Aug 14, 2015 | 12:25 PM
jwindwood's Avatar
Ok. Took it to a Jaguar independent garage today. He initially thought timing chains, but they are all very recent with metal tensioners. He did a compression test which shows three cylinders to be below par, two on one bank, one on the other. It is this that is producing the shaky idle. The car still drives fine so I've decided tpo put up with it until I decide whether it's worth a rebuild.....
Old Aug 14, 2015 | 06:09 PM
ysgeye's Avatar
My xj8 idles roughly. I am of the opinion that there is/are intake gasket leak(s).
ysgeye's Avatar
Does anybody know what the torque values should be for intake manifold bolts?
Thanks.
Old Aug 15, 2015 | 12:52 AM
JagV8's Avatar
Check fuel trims using OBD live data.
Old Aug 15, 2015 | 01:12 AM
XJR Pilot's Avatar
When I get that condition, it is usually a bad spark plug or wire leading to the plug. You should put an OBD reader on it to verify.
Old Aug 15, 2015 | 08:16 PM
ysgeye's Avatar
When i sprayed quick start at the intake gaskets, the rpms increased and that is the reason i think i have vacuum leaks at the intake
Old Aug 15, 2015 | 09:50 PM
Don B's Avatar
Hi ysgeye,
According to the Workshop Manual, the intake manifold-to-cylinder head bolts should be torqued to 21 Nm (16 ft. lbs.).
You can download the X308 Workshop Manual at the link below, courtesy of our member feloniousmonk. It's a very large file (66MB):
http://dl.dropbox.com/u/13224034/XJ-...Manual.pdf.zip
Cheers,
Don
magmedia
Aug 15, 2019 08:54 PM
LilaJagHubby
US Lower Atlantic
Mar 1, 2017 10:20 AM
philwarner
Jan 31, 2016 09:36 AM
magmedia
Oct 8, 2015 03:28 PM
donald ebanks
Sep 30, 2015 07:08 PM
