XJ40 ( XJ81 ) 1986 - 1994
Door Latch
Old Oct 14, 2010 | 08:06 AM
mrtalkradio's Avatar
Default Door Latch
Here we go. Passenger left side needs replacement. Can a 94 fit in my 90?
Old Oct 14, 2010 | 10:05 AM
retromotors's Avatar
Uh .... color me confused.
Passenger left side? In New Hampshire?
Do you have a RHD car, or did you mean left side rear?
Or ... more likely, do I just need another cup of coffee ....?
Old Oct 14, 2010 | 06:17 PM
Lumppy47's Avatar
Most likely the problem with your door latch is a plastic part that activates when you pull on the handle,if you are handy you can make one of these parts from aluminum an not have to worry about breaking it again. Also the handles are the same both right and left and look to be made out of pot metal. i belirve they are the same 88 to 94.
Old Oct 14, 2010 | 08:56 PM
Sorry about that. Left side passenger, if left being from sitting in the drivers seat (left side in America).
Old Oct 14, 2010 | 08:57 PM
Thank you lumpy. I will post results of either handiwork, or the replacement from my favorite bone yard.
Old Oct 14, 2010 | 09:32 PM
If you can't find what you're looking for at the boneyard, give me a shout. I may be able to help.
Old Oct 15, 2010 | 04:21 AM
Unless I am mistaken, highly possible, the handles are different left to right, because the bit that moves the latch rods is on the opposite end, left to right.
However, actuators etc can be swapped because you can get them out of their support frame and turn them around.
Could be wrong though
Old Oct 16, 2010 | 01:58 PM
Thank you Sir, I found one at the boneyard.
Old Oct 16, 2010 | 06:31 PM
No problem ... glad you got it worked out.
Regards, Retro
99xk8guy
Sep 29, 2025 10:51 PM
kevinl
Oct 31, 2019 06:15 PM
mrsimpson
Sep 15, 2015 01:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
Jay48
Sep 7, 2015 09:30 PM
