XJ40 ( XJ81 ) 1986 - 1994
Driver's outside door handle - limp?
Old May 11, 2008 | 02:13 PM
kreal's Avatar
Default Driver's outside door handle - limp?
Hi folks,
I have a 1991 XJ6 Sov. that was imported, gray market car.
Drivers outside door handle is limp, will not open the door when lifted. Could a rod have come disconnected?
Inside handle works as it should.
Thanks in advance.
Paul
Old May 11, 2008 | 11:16 PM
kreal's Avatar
Default RE: Driver's outside door handle - limp?
Hi, thanks for your reply.
Yep I'm definitely going to have to fix this, as I think Im going to drive this car a bit, tired of seeing it just sit in the garage. Put under 50 miles on it since I purchased.
The handle its self lifts up fine, and is not broken externally, it must be internally, where it connects to the rod. I wonder if I can perhaps weld the pot-metal together?
Also, was wondering where the plug for the car cover is located, for the factory alarm cord? I've looked all over the front end and can't seem to find it.
Also, how hard is it to find a replacement factory chrome wire Jaguar wheel? 15 inch.
Old May 11, 2008 | 11:18 PM
kreal's Avatar
I plan to tear into the door panel to figure out this handle problem by next weekend, will let you all know the results. If anyone else has any tips, etc I would appreciate.
Also..where would I purchase a new handle?
Old May 12, 2008 | 01:57 AM
JagtechOhio's Avatar
If it still feels like there is spring tension on the handle when you lift it, you may be in luck. Don't buy anything 'till you have a look inside. The plastic bellcrank may have come off the door latch plate, or the door latch arm may have broken off. You can private message me if you need more info...the handles are not that expensive or hard to change, but you have to swap over the lock barrel. The latch assy is a royal pain if you were that unlucky, but it happens.
Old Sep 24, 2008 | 08:52 PM
kreal's Avatar
HI all.
Well my door handle is broken.
Does anyone know where I could find a USED, or NEW, good condition driver front door handle for 1991 XJ40? Used will work! xkreal@aol.com
Old Sep 24, 2008 | 11:45 PM
Bnc2doz's Avatar
Hey Kreal,
There are a number of trustworthy people on these forums who sell parts, I'd go to them first.
Good luck!
Old Oct 1, 2008 | 12:42 AM
93xj6's Avatar
When we first bought my 93 on ebay it had this problem, but the owner replaced it before we took delivery, and it worked great for 2 years. now the problem is coming back on the rear doors. I noticed it seems worse when it's hot out, which seems wierd to me. It's an on and off problem, but im assuming it will only get worse
kevinl
Oct 31, 2019 06:15 PM
Dz1rfj
Jul 17, 2018 10:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Dz1rfj
Sep 16, 2015 03:44 PM
hoodun
Sep 7, 2015 07:02 PM
