Dumb question: Unknown boxes
Old Jul 2, 2018 | 03:33 PM
mlindblom's Avatar
Default Dumb question: Unknown boxes
Hi
Dumb question: What are these two components for (see picture)?
I have only worked on old (read simple) Volvos from the 60s in the past. The jag is quite complex in comparison so I have a lot to learn =)
Jaguar XJ12C, 1976
Thx
Marcus
Old Jul 2, 2018 | 03:46 PM
Jose's Avatar
the large tank might be a Vacuum Reservac tank. If not a vacuum tank, then it is a Coolant Recovery tank. The small box is where a spare key would have been placed at the factory. Serves no other purpose except to maybe hide a tool to open the bonnet if the pull cable breaks.
Old Jul 2, 2018 | 04:05 PM
new mexico's Avatar
Originally Posted by mlindblom
VACUUM tank
Hi
Jaguar XJ12C, 1976
Thx
Marcus
Old Jul 3, 2018 | 10:13 AM
JagCad's Avatar
Odd. I have only a bit to offer.
1. I found a pocket almost directly over the wheel on the drivers side. (HD). on the wing wall. Supposedly the receptacle for a small box and the emergency key. als, none there in my car.
2. Now, because of this post, I'll have to look under the bonnet of my car and see what is there. Or, is it in front of the wheel ? I see a lamp bucket....
Carl
Old Jul 3, 2018 | 12:39 PM
Jose's Avatar
look behind the lamp bucket, that's where those pockets are inthe Series 3.
Old Jul 6, 2018 | 06:48 AM
mlindblom's Avatar
The picture is in front of the right/front wheel. The big black box could maybe be for vacuum (for the heater/AC valves?). I first thought a charcoal canister...
The small box can hardly be for some spare key, has a cable connected to it (cannot follow it all the way). I took another picture:
Old Jul 6, 2018 | 06:59 AM
Doug's Avatar
The big one is definitely a vacuum tank. On the V12 Series IIIs it's a vacuum reserve tank for the power brakes. It might serve alternate purposes on other models, when fitted.
The small one is a mystery to me. If you have the time you could pick the appropriate listing here.....
https://www.jaguarclassicparts.com/u...r-vehicle-info
....and scroll thru the pages until you see it !
Old Jul 6, 2018 | 07:08 AM
Jose's Avatar
in the first picture it looked similar to the spare key box welded to the inner wing in Series 3 XJ, but obviously it is not. Then it could be an ignition amplifier, or ignition or coil or ballast, but why would it be located under the fender / wing?, so it is probably not that either.
No clue except to follow the wiring harness to see where it leads.
Jeff in Tucson
Aug 31, 2015 10:01 PM
jimlombardi
Mar 31, 2015 06:08 PM
Pompeygra
Feb 5, 2011 08:19 AM
Skid Mark
Nov 7, 2010 07:58 PM
JimC64
Oct 26, 2007 12:14 PM
