Engine starter
Old Aug 27, 2015 | 08:25 PM
adenshillito's Avatar
Default Engine starter
On a 1985 XJ6 Series 3 Engine with EFI where does one spray ENGINE STARTER FLUID into, which port, plug or pipe is the one? Just want to make sure before I blow anything up
Old Aug 28, 2015 | 08:12 PM
Jag-o-nomic's Avatar
Hi adenshillito,
Sorry no one got back to you sooner on this one.
Off side (drivers side) front of engine.
There is a large air cleaner canister / cylindrical box which has a long 2 inch ish wide cone attached to it which protrudes through the body work next to the fan shroud and radiator.
The opening of this tube is the air induction for the engine and is where you want to point your can of starter.
Cheers,
Nigel
Old Aug 30, 2015 | 09:16 AM
amaezing's Avatar
I to am sorry that no one responded sooner. I was out of town with limited internet access.
Jag-o-nomic is absolutely correct.
Old Feb 17, 2016 | 02:17 AM
And on a series 2 carb engine?
Old Feb 17, 2016 | 02:23 AM
With the aircleaner OFF, a VERY SHORT SNIFF into each carby. Bloody dangerous that way in MY opinion, BBQ Jag is terrible tasting.
They can and will spit back with that stuff, and scare the pants (being polite coz its a public forum) off you, trust me.
Fit the aircleaner, without element if you like, and a quick SHORT SNIFF up the intake snorkel.
Old Feb 17, 2016 | 02:48 AM
Ok, I am too scared now.
Old Feb 17, 2016 | 03:38 AM
We will hear it across the ditch, HA.
No fear, just good old common sense, and Kiwi's have plenty of that, just like us.
Dont overspray it, just a short, sharp squirt. It does not take much of that stuff.
Old Feb 17, 2016 | 03:56 AM
Daf11e's Avatar
Does carby cleaner have a similar effect Grant? When I last cleaned them and put back on I missed some gunk ( being ****) so I sprayed the throat...when I started it...Bang Flash...wet myself. Or maybe it was too rich.
Old Feb 17, 2016 | 05:05 AM
Yep.
The can says so on the label.
Great for BBQ Huntsman Spiders, oh boy.
Most anything like Carby clean, Brake Clean, etc is highly inflammable.
Old Feb 17, 2016 | 07:05 AM
JagCad's Avatar
There is a "safer" way to prime this engine. Not that hard, either.
Remove the spark plugs and add a small amount of fresh gas/petrol.
replace the plugs quickly and crank.
It should fire.
Might work with the "ether", but, it evaporates quickly.
If the engine coughs, when you give the intake a squirt, and the fire comes out, keep cranking, it may draw it back in....
Easier on top side carb'd engines.
Carl
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
OkieTim
Sep 2, 2015 12:48 PM
TC Johnson
Sep 2, 2015 09:30 AM
