Fuel change over switch
Old Aug 16, 2021 | 02:10 AM
Hktk's Avatar
Default Fuel change over switch
Fuel change switch/button on my Jag Series 3 1985, when pressed does not stay in. If I press and hold I can tell that the fuel switches tanks. Any advice?
Old Aug 16, 2021 | 05:22 AM
Jose's Avatar
sounds like the plastic locking cam broke off inside the switch. Best to replace the switch.
First step is to order a good used switch from David at www.everydayxj.com
Old Aug 16, 2021 | 06:14 AM
mikega's Avatar
Jose has given the response everyone here will give so go by that.
Old Aug 16, 2021 | 06:35 PM
Hktk's Avatar
Will do. Thanks all.
Old Aug 17, 2021 | 07:04 AM
yachtmanbuttson's Avatar
I also found that my plug on my changeover switch was constantly coming loose. So I wrapped a zip tie around my plug and switch - problem gone.
Old Aug 17, 2021 | 07:58 PM
mikega's Avatar
Did you photo that so you can share with us?
Old Aug 18, 2021 | 07:18 PM
mansterckp's Avatar
ah one of the first issues encountered and fixed in my jag, brings a tear to my eye,
While you wait on a replacement a little folded piece of paper in the gap on the switch did the trick for me, swapping the switches can be iffy but take your time and you will be fine.
Old Aug 20, 2021 | 07:36 AM
Sorry, was away for a couple of days. Here is a pic of the zip ties holding the electrical connections together. As you know, poor electrical connections cause many bad and hard to find problems. Especially if they are intermittent. I made a career in the computer industry back in the day of second generation computers with printed circuit boards with the gold connectors. Pull card, clean connectors; problem go away.
Old Sep 9, 2021 | 04:12 AM
Hktk's Avatar
Hi all,
As advised, just received a new fuel switch. Can someone guide me how to install?
Thanks.
Old Sep 9, 2021 | 07:12 AM
Gently prise the old switch assembly out from its holder. It's only being held in by two pins as you can see from my pic above. Then unplug both of the old plugs. If it were me, I would tab a bit of dielectric grease on the probes in the new switch, then plug the two plugs in. I would also zip tie the assembly like you see in the pic above. Gently push the whole assembly back into the plastic holders. Done. The saying that helps me remember which tank is which (the lit arrows are of no use - too dim) is : "Left-In; Out-right"
Old Sep 9, 2021 | 07:36 AM
Yellow series3's Avatar
Your '85 probably has wood veneer and separate holes for each switch. You can pry the switches out through the front but be careful to not chip the wood. If you want to remove the panel and clean all the contacts back there, etc here is a short video:
Old Sep 9, 2021 | 09:25 AM
motorcarman's Avatar
For some reason, the factory workers sometimes installed the switches and spread the spring steel mount retainers 'OUT' so the switch will NOT come out by prying.
I have had to remove the veneer and use long-nose pliers to bend the spring steel 'wings' back in to remove the switches.
Don't know why but I have had to do this DOZENS of times when I worked on the old sedans everyday for a living.
Old Sep 9, 2021 | 02:58 PM
JagCad's Avatar
Yup, trained myself. left in,. right out!!
Old Sep 9, 2021 | 07:57 PM
Hktk's Avatar
Thanks everyone. I have replaced the switch successfully.
Couldn't do without your help? Great people and forum.
Thanks.
Debbie Bean
Jul 28, 2016 07:41 PM
ahunt4
Jan 20, 2015 10:32 PM
carlso20
Aug 7, 2012 06:16 PM
dann59
XJ40 ( XJ81 )
Oct 7, 2011 01:44 PM
last2letUdwn
Aug 11, 2008 09:27 PM
