topping up brake fluid
Old Sep 7, 2020 | 12:28 PM
peter J's Avatar
Default topping up brake fluid
Noticed that the brake fluid was low in the resevoir of my 1973 xj6. the label says to use girling or castrol . the fluid is a green color. what should i use to top up?
Popular Reply
Sep 7, 2020, 05:13 PM
motorcarman's Avatar
motorcarman
Top Answer: 3
I always hated it when people would top up the fluid as routine maintenance because the reservoir volume is calculated to be LOW when the brake pads were worn enough to allow the caliper pistons to have enough fluid displaced to cause the level indicator to illuminate.
If there is NO LEAK and the level indicator comes ON, then a brake pad change is required!!!!
I'm sure the engineers spent time to calculate this and NOBODY uses this logic.
Even when I replace the fluid in the system I try to put the level at the same point before I drained/flushed/replaced the fluid. (recommended every 2 years)
Just me thinking out loud.
Old Sep 7, 2020 | 04:00 PM
nostromo7's Avatar
Green? That's not good... Either your car has very very old Castrol-Girling Green fluid—which I think would have been the factory-recommended fluid in '73—or the fluid is so old contaminants have turned it green.
To be safe I would flush the system entirely with new fluid, rather than top it up. Castrol-Girling Green was replaced by their Amber fluid in the late 1970s, a.k.a. Castrol-Girling "Universal" fluid; the Universal fluid is what's spec'ed in my '88 Series III. The modern equivalent is Castrol DOT4, but really any DOT4 fluid should do.
Old Sep 7, 2020 | 05:13 PM
Old Sep 7, 2020 | 07:09 PM
peter J's Avatar
Thank you both for your replies!
Old Sep 10, 2020 | 11:18 PM
redtriangle's Avatar
I prefer to use the BLUE coloured Dot 4 fluid. Reason? Easier to see the fluid level in the (aged) yellowed plastic master cylinder reservoir !!!
My two shillings worth.
Pete
Old Sep 11, 2020 | 07:12 PM
yarpos's Avatar
mmmmm you would think they would have put it in the owners manual wouldnt you?
Old Nov 14, 2023 | 05:55 AM
yovenim's Avatar
Banned
I always hated it when people would top up the fluid as routine maintenance from the car garage mussafah abu dhabi because the reservoir volume is calculated to be LOW when the brake pads were worn enough to allow the caliper pistons to have enough fluid displaced to cause the level indicator to illuminate.
I'm currently preparing my car for it's MOT at the end of February, and as such doing jobs where I can on my days off. (Currently I've had to replace the lower ball joints and doing the track rod ends next week!) Today I was checking under the bonnet to check the fluids and I noticed the brake fluid is looking lower than usual. Can I simply open the cap and add more fluid? Or do I have to bleed the brakes? I'm not 100% sure I can just top up as I thought exposure to air had a negative effect on the fluid? Thanks,
Old Nov 14, 2023 | 06:28 AM
Doug's Avatar
Yes
Old Nov 15, 2023 | 03:16 PM
The brake fluid reservoir caps are VENTED for air to displace the fluid as the level drops.
It is always exposed to air.
The small vent hole might limit the exposure but it is always there.
Old May 12, 2025 | 02:01 PM
Movieboxpro's Avatar
Default Movieboxpro
MovieBoxPro APK is a popular streaming application that allows users to watch thousands of movies, TV shows, and dramas for free. It offers high-quality content from Hollywood, Bollywood, and other international industries, making it a great choice for entertainment lovers. With its user-friendly interface, regular updates, and wide selection of genres, MovieBoxPro APK has become a favorite among those who enjoy on-the-go streaming without needing a subscription.
RGPV6S
Sep 6, 2020 09:49 AM
orangeblossom
Sep 27, 2016 02:10 AM
SSMcDonald
XK120 XK140 XK150
Jun 19, 2014 11:41 AM
yeldogt
Feb 13, 2011 12:23 PM
Feb 9, 2007 11:03 AM
