Well damn!!!
Old Jan 27, 2025 | 08:58 AM
Darrenmb's Avatar
Veteran: Navy
Default Well damn!!!
She’s been trouble free for a long time now and then this!!! I knew I was tempting fate when I told my wife that we could get in her and go anywhere, she’s super reliable!!! Should have knocked on wood!!!
I know it’s a common problem but cannot remember which valve I need to be looking at! Running on left tank and all is good, running no. Right tank, left tank overflows!!!
Old Jan 27, 2025 | 10:41 AM
I *HATE* it when that happens!!
It's a good thing that drain works or you'd have a real mess on that paint.
(I can tell you how I know that)
Old Jan 27, 2025 | 12:25 PM
slofut's Avatar
These cars need a check valve like aircraft to bleed off water and check condition of gasoline. Inevitable given the age, culprit is probably the changeover valve but the reason is probably dirty tanks.
Old Jan 27, 2025 | 01:37 PM
Jagboi64's Avatar
I think it's a non return valve in the wheelwell is stuck closed. One is normally open, the other normally closed, but I can't remember which side is which. I'd replace both.
Here is the testing procedure: https://www.jag-lovers.org/newbies/s...hangeover.html
Old Jan 27, 2025 | 01:53 PM
Darrenmb's Avatar
Veteran: Navy
thanks that gave me the info I needed, left valve is normally open!!!!
Old Jan 28, 2025 | 02:39 PM
Darrenmb's Avatar
Veteran: Navy
Well, it looks like I'm swapping out both valves!!!! Got sometime this afternoon to check everything out and of course it’s working perfectly now!!!! I can switch the tanks over and by holding open the flap, i can see the fuel returning to whichever tank I select!!!
Old Jan 28, 2025 | 04:25 PM
David84XJ6's Avatar
Could be the tank switch on the dash that moves power to the correct valve when you switch tanks. Push switch in and out multiple times to clean contacts.
Rgds
David
Old Jan 28, 2025 | 04:38 PM
Darrenmb's Avatar
Veteran: Navy
Rgds
David
good idea, can’t hurt for sure
Old Jan 28, 2025 | 07:14 PM
redtriangle's Avatar
Talking
Prohibition Signs - No Smoking In This AreaSuggested trunk sign for all XJ's
Old Feb 1, 2025 | 02:04 AM
yachtmanbuttson's Avatar
I've taken that switch apart and cleaned the contacts. Not too bad a job and it did the trick.
Bill
sanchez
Feb 17, 2023 02:04 PM
Comfortablynumb
Apr 28, 2022 06:04 PM
oscarvelay
Aug 25, 2021 11:14 PM
VancouverXJ6
Sep 4, 2017 01:52 AM
yukscn
Aug 14, 2017 11:52 AM
