What size is the thread for the oil pressure sender?
Old Nov 12, 2019 | 12:01 AM
smaceng's Avatar
Default What size is the thread for the oil pressure sender?
I am trying to bring back to life a Proteus "C type" Jaguar.....plastic body with a Series 11 xj6 running gear. Engine # 8L41420.
Oil pressure gauge does not work and I need to plumb in a known good one to check if I even have oil pressure.
What is the thread size for the standard sender so I can rig up my external oil pressure gauge.
Thanks,
Scott in CA
Old Nov 12, 2019 | 03:12 AM
I used a sump plug 1/2" UNF, for the adapter on the V12 20+ years ago, and its still fine.
Same basic sender, just different innards for the 6 to 12.
Good luck.
Old Nov 12, 2019 | 12:57 PM
Robert Wilkinson's Avatar
1/4 inch BSPP (British standard pipe parallel)
Old Nov 12, 2019 | 02:42 PM
motorcarman's Avatar
The oil pressure switch should be 1/8 pipe (27 TPI, I think).
Might be easier to check from that oil pressure hole?
Old Nov 12, 2019 | 03:56 PM
The switch is 1/8 BSPT (British standard pipe tapered; 28 TPI). Not the same as 1/8-27TPI NPT (National pipe tapered)
Old Nov 12, 2019 | 07:22 PM
Maybe I misread the ask, dunno.
The oil light (idiot light) tapping is the 1/8 as stated, but I thought he was asking about the Gauge sender, which is the larger if the 2 on the oil filter housing.
Maybe I need more coffee, or something??
Old Nov 12, 2019 | 09:03 PM
If you are simply trying to get oil pressure readings, I would try the 1/8 hole for that. The 27, 28 and M10x1.0mm all so close that they are easy to find adapters.
Also note that if you do not get crazy tightening with threading any of these you will likely not damage the block.
Use brass adapter and the threads will deform the adapter before the block. The seal will be 'good enough' for the short duration of the test!!(teflon tape?)
The British Standard sending unit is not worth damaging threads for this application.
People are going to do what they want so carry on.
bob
Old Nov 17, 2019 | 06:36 PM
smaceng's Avatar
I am going to try to fix the electric gauge. I have a good gauge, but the sender is an open circuit. I have bought a new sender. Cheers, Scott in CA
twack
XJ40 ( XJ81 )
Jul 7, 2019 10:02 AM
sanchez
XJ40 ( XJ81 )
Jul 27, 2018 12:33 AM
benzjag
Apr 13, 2018 07:58 AM
jomo
Jul 17, 2015 07:11 PM
ahunt4
Feb 7, 2015 02:23 PM
