What is the wiring pair on the left side in the trunk hinge?
Old Jan 26, 2020 | 10:46 AM
yachtmanbuttson's Avatar
Default What is the wiring pair on the left side in the trunk hinge?
I'm stumped even after searching the wiring diagram. There are two wires going in and out of the left drivers side trunk hinge assembly. One us a orange with green Trader, the other orange with either ref or purple tracer. The ends going forward are bullet male ends, while the longer wire that goes rearward has a female right angle jack. I find nothing that either one of these plug into. Anyone have any ideas?
Thanks, Bill
Old Jan 26, 2020 | 12:09 PM
Jose's Avatar
the lock solenoid near the license plate?
Old Jan 26, 2020 | 12:27 PM
I was thinking the same thing, but even my parts manual for a Series II doesn't show a part number for such solenoid. As it turns out, I have to replace that hinge anyway, so that wire will just go away.
Old Jan 26, 2020 | 12:29 PM
Jose's Avatar
sorry, I thought it was a Series 3.
the orange wires could be for the Antenna.
Old Jan 27, 2020 | 01:36 PM
Good thought, but... why would they be running through the lid hinge? I would only think it would be running through the hinge to get into the back of the lid for something (like the passenger side is with the license plate lights and reverse lights and trunk lid lights). I'm now thinking that maybe some PO had changed that hinge with an S3 hinge and it was wired for a trunk latch solenoid. I will never know. But at this point I don't care because I've troubleshot that hinge has being well worn and needing replacement anyway. Have contacted David at EverdayXJ or another. But I appreciate the response and thoughts. Thanks
Old Jan 27, 2020 | 02:04 PM
David84XJ6's Avatar
Bill,
I just looked at hinge arm pin and there is no room to work on repairing elongated hole with hinge installed. I think you have solved another mystery as to some reports of Lid opening to stops at 31-33" then settling to 28"on the springs.
Rgds
David
Old Jan 27, 2020 | 03:43 PM
Nice to be part of the solution for a change, instead of the problem!
Old Jan 27, 2020 | 08:44 PM
Yellow series3's Avatar
My new word for the day. Past tense of troubleshooting.
Old Jan 28, 2020 | 10:59 AM
JagCad's Avatar
Troubleshot????
Carl
skinnypuppy_22
Apr 1, 2018 09:08 PM
IcyBlueRose
Feb 20, 2015 06:07 AM
pipsqueek
Feb 1, 2014 05:29 PM
adriaxj8
Aug 13, 2012 05:21 PM
RalphFurley
Apr 23, 2008 04:26 AM
