1991 V12 crank, no start. Pump working.
Old Jun 3, 2014 | 05:11 AM
jaguarlars's Avatar
Default 1991 V12 crank, no start. Pump working.
No spark. No ticking injectors. I have 12V at coils and fuelpump working. Water temp sensor ok. Any ideas?
Cars is 1991 US with Marelli.
Old Jun 3, 2014 | 06:51 AM
Doug's Avatar
Simultaneous no spark and no injector pulse sounds like a crank sensor problem. There are two. Most guys replace both at once but others will chime in on that.
Old Jun 3, 2014 | 06:54 AM
jaguarlars's Avatar
I know this is a common fault on six cylinder, but never heard about it on the V12`s. Anyone knows if this is a common problem?!
Old Jun 4, 2014 | 03:36 AM
jaguarlars's Avatar
Crank sensor working.
Old Jun 4, 2014 | 08:54 AM
smachell's Avatar
I have a 1989 that I replaced the Marelli rotor on, only 1/2 getting fire.
mine has the high /lo rotor, 6 fire on top, 6 fire on the bottom.
apparently common problem with the rotors.
Steve.
Old Jun 5, 2014 | 03:53 AM
jaguarlars's Avatar
Turned out it was the marelli ecu. Replaced and now works again!
Old Jun 5, 2014 | 07:33 AM
Doug's Avatar
Good work !
Old Jun 5, 2014 | 08:55 AM
smachell's Avatar
congratulations
Dagny
Jun 11, 2024 01:06 PM
kossevv
Feb 21, 2021 12:49 PM
picard
Sep 19, 2015 08:13 PM
jagfool
Sep 14, 2015 07:50 PM
1964Daimler
Sep 9, 2015 11:28 AM
