95 XJS Convertible seat cushion replacement
Old Oct 4, 2022 | 09:44 AM
NHXJS's Avatar
Default 95 XJS Convertible seat cushion replacement
I ordered a new driver seat bottom to replace my old worn seat. I am trying to find instructions/advice on removal and installation of the bottom seat cushion. Do I need to remove seat from the car or can it be done with the seat frame still attached to car? I would like to avoid having to remove the seat as it appears to be quite a frustrating task. Any advice would be appreciated.
Old Oct 4, 2022 | 10:42 AM
Vee's Avatar
Vee
You'll 100% absolutely have to remove it from the car.
Does that order include the leather, or just the foam? You may need to also replace the rubber diaphragm at the bottom of the seat too. Do you have seat heaters?
You'll likely have to separate the back from the bottom.
Old Oct 4, 2022 | 10:46 AM
NHXJS's Avatar
It is the cushion and the leather cover. No seat heaters.
Old Oct 4, 2022 | 12:06 PM
Vee's Avatar
Vee
You may want to purchase a seat diaphragm. Mine was in terrible shape. I ended up moving the passengers seat to the drivers side while I waited for the much needed diaphragm to arrive for the drivers seat.
Old Oct 4, 2022 | 03:15 PM
Timeisrelative's Avatar
Where did you find just the seat bottom? All i can find are full sets
Old Oct 4, 2022 | 04:27 PM
NHXJS's Avatar
I found it at https://gahh.com/ GAHH Automotive. Haven't received it yet but I was also having a hard time finding the base for my car and then this site came up last week on a search. It looks legit. We will see. They shipped it out within a couple days of ordering, arrives on Thursday.
I just ordered a diaphragm from Ebay. Not looking forward to this install. Sounds like a real trick to get the seat out.
Old Oct 4, 2022 | 05:29 PM
ptjs1's Avatar
I've always found it fine taking the seats out of my convertible ( as long as the seat motors are working
Move it all the way back and undo the two screws at the front of the runners. Then power it all the way forward and remove the 2 screws at the back holding the runners to the car.
Carefully disconnect the wiring plug and lift the whole (heavy) seat and runner assembly out.
A good time to then vacuum and shampoo the carpets!
Good luck
Paul
Old Oct 4, 2022 | 07:44 PM
MSGGrunt's Avatar
Are the seat bottoms on the XJS swapable from side to side? Not the base, but the cushion part. This is a common swap on older Mercedes as the passenger's cushion usually gets much less use and is in better condition.
Old Oct 4, 2022 | 08:13 PM
petemohr's Avatar
Like ptjs1 said the seats are easy to remove. Easier on the convertible with the top down. Don't sweat it.
Old Oct 4, 2022 | 09:19 PM
Vee's Avatar
Vee
Yes. The almost 30 year old foam on the passengers side would be interchangeable. At that point, I'd buy some foam and make new ones...but you do what works for you.
Old Oct 5, 2022 | 07:48 AM
NHXJS's Avatar
Thanks for all the encouragement and advice. Parts should be here by the weekend. I will let you know how it came out. Gonna give it a whirl.
Old Oct 10, 2022 | 02:44 PM
NHXJS's Avatar
Project complete. Thanks for the advice and help. The seat bottom that I was expecting to be a fully assembled cushion and leather turned out to only be the leather. The item description was a bit deceptive in my opinion. BUT the leather was nice and was the right one for my car. I decided to forge ahead. Removed the seat and disassembled without too much trouble. Used my old cushion and a new diaphragm which I got from Paul's Jaguar via Ebay. End result is very good. The leather is a tad looser than the other seat due to the poor condition of the old cushion but it is done now and looks very good. Highly satisfied by the result. Thanks again for your help and encouragement!
Old Oct 10, 2022 | 03:17 PM
ptjs1's Avatar
Steve,
Well done! Let's see some photos!'
Paul
Old Oct 18, 2022 | 04:44 PM
NHXJS's Avatar
Here are a couple pics. Leather would have stretched tighter if I had a new pad instead of the old crappy one. I am happy with it for he time being..
Old Oct 18, 2022 | 08:11 PM
ptjs1's Avatar
Get some new foams, Steve. That new leather deserves it!
Paul
Old Oct 19, 2022 | 10:49 AM
Vee's Avatar
Vee
The side bolsters is what really needed to be replaced in mine. The middle section was in pretty decent shape.
The bolsters were unusable.
It appears you only replaced the seat bottoms? What was the price on that?
Thanks.
Old Oct 19, 2022 | 11:15 AM
jal1234's Avatar
Sometimes you can use a steam machine to rejuvenate seat foam and not replace it. Here are a couple of videos on the process.
https://youtu.be/zH-s2ald9HA
https://youtu.be/5rndD6tzZPo
Jon
Old Oct 19, 2022 | 11:22 AM
Vee's Avatar
Vee
A big block of new foam was $40.
I did have to buy an electric knife. $15
I may have had to buy some glue as well. I glued some fiberglass sheet to the slit where the seat support goes into the bolster foam to make sure the bar did not eventually cut through the bolster foam over time. $5.
Old Oct 20, 2022 | 08:28 PM
MSGGrunt's Avatar
Using steam on seat foam will bring it back to life and probably would have filled out your covers better. I did this on some BMW E30 sport seats and it worked like a charm.
baloozman
Nov 19, 2019 02:29 PM
Russell Routt
Feb 24, 2016 05:34 PM
EJ Garity
Aug 17, 2015 12:09 AM
AirCav
Dec 25, 2011 02:28 AM
stonehenge kid
Jul 13, 2011 07:20 PM
