Boosting the battery
Old Mar 11, 2018 | 07:42 PM
Refstuff's Avatar
Question Boosting the battery
Battery is in the trunk (boot). It is dead. The doors as well as the trunk has an electronic locking system that needs the battery to function. So I'm stuck, can't open the trunk without battery power and can't boost the battery without opening the trunk. Any workarounds?
Old Mar 11, 2018 | 08:25 PM
Mark SF's Avatar
The trunk has a lock that can be opened with a key.
Old Mar 11, 2018 | 08:26 PM
Refstuff's Avatar
Tried that but still won't open. I think the electronic lock must somehow override the manual lock.
Old Mar 11, 2018 | 08:32 PM
Mark SF's Avatar
No, it's probably just stiff from lack of use. Apply some spray lubricant, and persist.
Another plan is, if you can open a door and then open the hood, is to apply a battery charger using the bulkhead pos terminal, left side .
Old Mar 11, 2018 | 08:36 PM
Refstuff's Avatar
The key turns freely but the latch can't be moved. I know its not sticking because up until yesterday it was working fine. Then I used the remote to lock the car and all doors and the trunk locked. The doors will open with a key, but not the trunk. The battery is so dead that the remote won't even lock or unlock the doors anymore.
I will look to see if I can find the bulkhead terminal.
Old Mar 11, 2018 | 10:02 PM
Padre's Avatar
Battery tender with cigarette lighter adapter? Trickle charge it for a while, see if you get enough power.
Padre
Old Mar 11, 2018 | 10:26 PM
Jagboi64's Avatar
The key is a bit weird, I think it has to be in the middle of the travel to be unlocked. Mine has the newer style key, so might be a bit different, but it's not all the way left or right, those are both locked positions.
I store mine for the winter with no battery in it, and I can easily open it with the key. On a 94 anyway no power is needed. If you have it, read the owners manual carefully to get the key in the correct position and it should open.
Old Mar 11, 2018 | 10:29 PM
malc4d's Avatar
Just a thought..
You are turning the key full to the left or right then back to the middle again?
I'm not sure if its left or right turn that allows the lock to open manually or central locking.
Old Mar 12, 2018 | 01:21 AM
warrjon's Avatar
Try turning key 90° so it is vertical in the lock.
Old Mar 12, 2018 | 05:49 AM
malc4d's Avatar
Do the "cigar" sockets have a continuous 12v supply ?
Old Mar 12, 2018 | 09:19 AM
Padre's Avatar
I'm not certain. Seems to vary by model.
If not, turn the ignition key. However, in my experience, all the other accessories will try to come on when the charge is received and the battery won't be charged. So, simple solution: turn off what you can (like radio), then pull the other fuses as needed.
Padre
Old Mar 12, 2018 | 11:08 AM
Mark SF's Avatar
No.
Old Mar 12, 2018 | 12:07 PM
sidescrollin's Avatar
The linkages are pretty simply on these cars. If you call a "pop-a-lock" type person, they should be able to get the car open.
Idk about the newer models, but if you have long-reach pliers, you can unscrew the mirrors from older models and pretty easily actuate the linkage at the door handle.
Old Mar 12, 2018 | 01:02 PM
Mark SF's Avatar
I can think of at least 3 places you can attach a battery charger :
1) Starter motor + terminal (thick wire, not the solenoid)
2) Bulkhead + terminal under the hood
3) One of the fuse holders on a non-ignition-switched feed
Old Mar 14, 2018 | 11:02 AM
Refstuff's Avatar
Thanks to malc4d, warrjon & Jagboi64 for insight about the lock.
Leave it to British engineers to come up with a totally non-intuitive way to operate something as simple as a lock.
snkpkp
Jan 14, 2021 09:52 AM
maverick3934
Feb 11, 2013 11:32 PM
Mark Scotton
24
Jan 23, 2013 09:27 PM
aldol
Dec 24, 2012 07:01 PM
