Bummed.
Old Apr 5, 2012 | 07:21 PM
M90power's Avatar
Default Bummed.
so i bought a couple of used BMW injector harnesses for the Jag. the connectors are all busted and chipped. the retaining rings have all fallen off. im pretty cross with the seller right now.
the EV1 injectors from osidetiger.com are all sold out too.
this blows.
Old Apr 5, 2012 | 07:39 PM
Mish_Mish's Avatar
Bring your *** here, we will hook you up. Maybe we will unravel your fuel management enigma here, by looking at my sexy V12 run
20120404 170802 - YouTube
Old Apr 5, 2012 | 07:43 PM
Doug's Avatar
Bad news, sorry
You could get 15 of these (12 for injectors, 2 for sensors, 1 spare), some decent wres, and make up a new harness in about four hours. A soldering gun, some tape.....
Injector connector fuel pigtail Ford Chevy VW GM Buick | eBay
Old Apr 5, 2012 | 07:48 PM
M90power's Avatar
i was just thinking that.
and yes, ive watched all of your videos many times. no need to repost. lol
just bought 15.
Old Apr 6, 2012 | 01:48 AM
warrjon's Avatar
M use good quality silicone insulated wire and you will never have trouble again with cracked insulation.
May I also suggest using a MIL spec connector to join the new harness to the old in the fender well.
Also document your new harness if the wire colour codes are different so if you need to do any work in the future you have a wiring diagram.
Old Apr 6, 2012 | 06:14 AM
M90power's Avatar
just bought 300 feet of crosslink 18 gauge from delcity.com
Old Apr 6, 2012 | 04:41 PM
M90power's Avatar
im looking at the injector groups here in my schematic.
1a, 3a, 5a
2a, 4a, 6a
1b, 3b, 5b
2b, 4b, 6b
is this correct? because my harness is wired
2a, 5a, 4a
1a, 3a, 6a
2b, 5b, 4b
1b, 3b, 6b
Old Apr 6, 2012 | 05:45 PM
Doug's Avatar
My schematic agrees with your schematic
Old Apr 6, 2012 | 06:02 PM
M90power's Avatar
so my injector harness has been mixed up at some point.
so i rigged up a temporary injector harness with the BMW stuff i had. no change whatsoever.
i dont think you guys understand just how rich im talking about here. it runs SO rich that i drained 5 gallons in about an hours worth of tinkering. my supercharged GP doesnt drain 5 gallons in an hour of driving.
Old Apr 6, 2012 | 08:50 PM
warrjon's Avatar
The 5 and 6 injectors being swapped around means someone has had them off. At a guess 5 and 6 would most likely not have the required fuel when it goes bang. This could make the other cylinders run rich but not that rich. You obviously have more than one issue that is causing you mixture problem.
As someone has been in there tinkering I would be checking every sensor for correct connection and operation.
Check the O2 sensors, obvious as they control fuel enrichment
engine coolant temp sensor - this provides cold start enrichment
IAT sensor - this provides 2% enrichment for ever 10°C fall in IAT
There is an idle mixture adjustment in the ECU although I would only touch this as a very last resort.
Old Apr 6, 2012 | 09:39 PM
M90power's Avatar
dont all 12 injector pulse at the same rate with the same amount of fuel?
as i asked earlier, whats the best way to check these?
ive got this bridged with piece of wire to get 5v, as i have removed my air cleaners.
jamey had his XJSC running nicely with this ECU, so for the time being im not going to touch this pot.
Old Apr 6, 2012 | 09:53 PM
warrjon's Avatar
No they pulse in batches and the on time is governed by inputs from the sensors. One other thing to check is Fuel pressure if this is way too high you will over fuel.
Old Apr 6, 2012 | 10:08 PM
Doug's Avatar
With a voltmeter. It's easy. Click here and scroll down.
O2 Sensor Test Information & Resetting the Light
Since yours in an '85 you should have the single wire O2 sensors. If by chance you have the 3-wire type, the signal wire (as opposed to the heater wires) is segregated from the other two
Completely off, including the housings that bolt to the throttle bodies? If so, are the bolt holes open? If so you'll have a huge vacuum leak
Old Apr 6, 2012 | 10:28 PM
M90power's Avatar
theyre single wire o2 sensors.
but after reading the whole article, its clear that o2 wouldnt effect the way the jag runs in open loop. unless....... the o2 sensors arent getting or sending any voltage at all. if the o2 reads 0 volts due to a broken wire it could cause the ECU to go full enrichment, right?....
no.
Old Apr 6, 2012 | 11:24 PM
Doug's Avatar
Hmmm.
I don't think so. I think it would just default to open loop fuel mapping. The TPS and Baro sensor are still the primary fuel metering players. The O2 sensors are more like trimming devices.
One thing.....check the oxy sensors in "Drive". At some point....can't remember the break...the system was configured to go open loop in "Park", as I recall.
GvilleVDP
May 14, 2013 01:42 PM
Delbert
Jan 8, 2013 08:37 PM
CinciXK
Mar 24, 2012 04:45 AM
djsomebody
Jan 25, 2012 07:20 PM
BlackVDP
Sep 9, 2011 05:09 PM
