Check Out What Marko Is Up To.
Old Aug 28, 2015 | 07:13 PM
JagZilla's Avatar
Thumbs up Check Out What Marko Is Up To.
I almost cried when he broke out the cutting wheel.
(function(d, s, id) { var js, fjs = d.getElementsByTagName(s)[0]; if (d.getElementById(id)) return; js = d.createElement(s); js.id = id; js.src = "//connect.facebook.net/en_US/sdk.js#xfbml=1&version=v2.3"; fjs.parentNode.insertBefore(js, fjs);}(document, 'script', 'facebook-jssdk'));
https://www.facebook.com/rust2rome/videos/10153148883438947/Have you seen the Pearl's magnificent 12 throttle bodies sticking out of the massive hole in the bonnet? Well this is how they got there and how I cut the hole in the bonnet all in a couple of minutes!
Posted by Rust2Rome on Friday, August 28, 2015
Old Aug 28, 2015 | 11:04 PM
Safari's Avatar
Any idea what brand/model those throttle bodies are?
Old Sep 3, 2015 | 02:06 PM
Jonathan-W's Avatar
Tears of Sadness or Elation !?
me kind of a mixture...
Old Sep 3, 2015 | 02:50 PM
Jonathan-W's Avatar
Remove
Rust2Rome It's off the shelf Jenvey throttle bodies with custom manifolds to make them fit. Original injectors with Emerald ECU and mostly original loom. Actually some of it is 6.0 loom and some of it is 5.3! It runs so much better with them and even helped the mpg on the motorway! I say go for it!
http://www.jenvey.co.uk/products2/tw...mm-pair-tbpxxi
Old Sep 3, 2015 | 03:07 PM
Jonathan-W's Avatar
Originally Posted by Jonathan-W
Remove
DCOE Throttle body 118mm long : TB body 40-50mm Pair - Jenvey Dynamics
if you are in the USA
https://www.borlainduction.com/3003-series.html
or better
http://foxinjection.com/pages/about-us
Old Sep 6, 2015 | 06:36 AM
Katoh's Avatar
Wow! love the look, any specs on Hp and torque?
Old Sep 6, 2015 | 11:52 PM
Katoh's Avatar
I just went through one of the sites that Jonathan-W Referred to and came across this, a complete package for the V12, looks awesome but mind you has the high dollar amount to go with it.
Throttle Body Kits : V12 Jaguar throttle body kit SF45 - Jenvey Dynamics
Old Sep 7, 2015 | 01:13 PM
Jonathan-W's Avatar
Yes,
usa link and price...
have deep pockets...?
CKJR04 V12 Jaguar throttle body kit SF45 - Fox Injection
these are not the ones that Marko is using, I do believe he used 6 IDF
TFPxxi TF body 40-50mm. Pair - Fox Injection
3 pair 683.03 us$
about 2050 us $
Old Sep 7, 2015 | 08:16 PM
Jonathan-W's Avatar
I do not see how those would fit with the aircond compres.
Old Sep 8, 2015 | 07:35 AM
Katoh's Avatar
I think things like the AC pump would need to find a new home, not that is a bad thing to do and actually can be a worthwhile upgrade, but the big one that scares me is getting access to the plugs and dizzy(distributor). In that case you I would seriously look into things like Megajolt and have coil packs tucked under there, its not the place you would want to visit often IMO.
Dz1rfj
Jul 17, 2018 10:29 AM
Horus
Sep 18, 2015 05:39 AM
Dz1rfj
Sep 16, 2015 03:44 PM
YycXJS
Sep 7, 2015 09:58 AM
Tar
Sep 6, 2015 11:24 AM
