Coupe' window motor Aussie solution
Old Jul 29, 2023 | 03:19 AM
Elm's Avatar
Elm
Default Coupe' window motor Aussie solution
For those XJS Coupe' owners of the Aussie variety, I have a solution to the failed electric window motor. I hope I am not duplicating someone else's post.
My nylon gear wheel had stripped teeth and I was unable to find a replacement gear.
I searched eBay for used replacement motors but the price and shipping were too expensive.
A VK - VS Holden motor can be had for about Au$160 but used ones like mine are available for half that, and with slight modifications, perform same as the original.
I can provide modification details for anyone interested.
Same 8 tooth gear
Height modification
Same assembly fitment
Old Jul 29, 2023 | 03:45 AM
Goodo.
Simple cars these XJS's.
The nylon "wheels" in the lift track, Bunnings, shower screen wheels, sweet as.
OR
Sliding door wheels from Rollco, Black colour, but I doubt the car cares.
Old Jul 29, 2023 | 04:55 AM
Greg in France's Avatar
Yes please!
Old Jul 29, 2023 | 08:39 PM
Elm's Avatar
Elm
Here is a link for new motors in Australia. I have not bought this item so I suggest you do your own research.
https://www.holdcom.com.au/2400ml
Here is a sketch of how I turned up these spacers on my lathe. I used aluminium stock, a sprint kart tie rod.
All dimensions in mm.
Old Jul 30, 2023 | 01:43 AM
So to be clear, you used the Holden unit in its entirety without any mods apart from the spacers, and it bolted straight into the door/window metalwork just like the original?
Old Jul 30, 2023 | 05:20 AM
Elm's Avatar
Elm
That's correct Greg. I super glued the spacers in place then JB Weld. I used spade terminals to connect to the existing motor terminals.
Robbo D
Feb 7, 2023 08:45 AM
Motard
Jun 19, 2020 07:40 PM
JagJagJag
Dec 22, 2013 10:03 AM
sidescrollin
Aug 7, 2013 06:27 AM
Love my Jag
Jul 16, 2012 09:49 PM
