Did I just screw myself? Fuel Return Hose
Old Jul 24, 2015 | 02:26 AM
Dymaxxion's Avatar
Default Did I just screw myself? Fuel Return Hose
So, I'm leaving on a short road trip tomorrow in my Jag (was?) and I'd decided to replace my car's fuel hoses before I left. I'd planned to do this sooner, but all the necessary parts hadn't arrived yet. Well, anyway I had everything today and Decided to tackle it the day before I left. Managed to cut myself at least 5 times and burn myself with the soldering iron, but I got the Injectors refurbished and the fuel rail hoses replaced. I was putting them back in when I noticed the fuel return hose (EAC9986) was looking very worn and a bit cracked. I figured that while I had the system depressurized I may as well replace that too, so being rather foolhardy (it was 1am) and imagining it was like the injectors I just snipped the rubber hose bit. Little did I know it was not like the others and there's what looks like a long ferrule on it holding it tight. Is there a way I can replace the rubber hose piece myself or do i have to ship it out to get it replaced? Could I just cut the clamp thing off and put a standard, screw-tight EFI clamp on?
Old Jul 24, 2015 | 03:34 AM
rgp's Avatar
rgp
short answer yes, although I fitted a gauge take on mine its just a hose on a pipe underneath the ferule
Old Jul 24, 2015 | 04:17 AM
baxtor's Avatar
If you saved the ferrule and the hard line fitting without damage just fit suitable efi hose into ferrule and then work that onto the fitting barbs. I renewed all mine recently and while it takes some effort it is quite a straightforward job, some lubricant will be required. I would not use a clamp on the fitting unless you can avoid clamping directly onto the barbs.
Old Jul 24, 2015 | 04:26 PM
Dymaxxion's Avatar
Thank you, I still have the ferrule and hard line, but I can't seem to get the hose out of the ferrule because it's so deep. Would cutting the ferrule off work? I know the functionality is debated on the fuel rail, but wilt return line function without them? what do they do for the return line? Would it help if I put a clamp over the line lightly?
Old Jul 24, 2015 | 05:49 PM
baxtor's Avatar
They take a bit of digging out, but new ones are generally easily obtained from auto or farm supply stores. Clamp might be ok so long as it is EFI type with a closed up size matching the original ferrule, not worm drive.
Old Jul 25, 2015 | 03:17 AM
user 652867429824's Avatar
after cutting mine, I held the ferrel in Vise Grips and then used a propane torch to heat it then needle nose to pull out, a xacto knife will scrape out what is left nicely, to polish up, used a dremel with a wire brush
Old Jul 25, 2015 | 03:51 AM
rgp's Avatar
rgp
found this for you,
XJS Series 3 V12 Jaguar OE fuel return hose EAC9988 NEW | eBay
Old Jul 25, 2015 | 02:16 PM
Doug's Avatar
I treat the supply and return pipe/hose assemblies just as I do the injectors--- cut off the old, install the new. I use the same ferrules on all. Just got done doing a set for my own car, in fact.
Attached Thumbnails Did I just screw myself? Fuel Return Hose-return-pipe.jpg
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
Bcrary3
Feb 21, 2023 04:29 AM
Wahooesprit
Dec 23, 2019 02:01 PM
explorer364
Sep 11, 2015 05:44 PM
