Fosseway Performance Calipers
Old Jan 30, 2020 | 04:23 PM
Jbaker229's Avatar
Default Fosseway Performance Calipers
I know there has been some talk on this forum regarding the upgraded Fosseway Performance Braking kit. My 93 was in desperate need of a brake overhaul. The rear calipers where seized, so I figured why not install the Fosseway kit upfront? I can report that kit does WONDERS for the car's braking performance. The brakes are way more progressive and offer substantially more power over stock, now a light touch of the pedal provides enough bite to bring the car to a stop. Certainly, some this can be attributed to the working rear calipers, but I was able to drive the car with working rear's and stock front calipers/rotors/lines and the Fosseway brakes are night and day over stock. If anyone is looking to substantially upgrade their brakes, I suggest the Fosseway kit.
Old Jan 30, 2020 | 05:06 PM
ronbros's Avatar
are they cheaper than factory stuff?
Old Jan 30, 2020 | 07:21 PM
Jbaker229's Avatar
Definitely not, they came in around 1800 US for the full kit. Insane, I know, but they are six-piston aluminum machined calipers.
Old Jan 31, 2020 | 01:45 AM
Greg in France's Avatar
I have long lusted after such an upgrade. As well as which you take several kilograms off the unsprung weight.
How easy were they to fit, please?
Greg
Old Jan 31, 2020 | 09:56 AM
Jbaker229's Avatar
They need to be shimmed for fitment, and the entire system needs to be bleed. If you are comfortable working on your XJS, you should have no problem.
Old Feb 1, 2020 | 03:14 PM
ronbros's Avatar
i use WILWOOD aluminm calipers, with EBC sloted/ plated rotors, around 1/2 the price of yours!
big weight saving compared to factory cast iron calipers!
if money was no object i'd probably use BREMBO stuff!
Old Feb 5, 2020 | 08:24 AM
JayJagJay's Avatar
Could you talk a little bit about that spacer, Ron?
What's the Deal-e-O?
Old Feb 6, 2020 | 03:57 PM
ronbros's Avatar
JJJ , i wanted a nice wide Stance from front view, just maybe handle better also?
but for wheels to fit without rubbing, at full lock, i'ts what i needed!
Atomic
May 14, 2016 09:52 PM
luds1
May 26, 2015 10:11 PM
calvindoesntknow
May 22, 2015 10:39 AM
XKRNorway
Mar 14, 2014 08:50 AM
adam699
Apr 6, 2012 02:06 PM
