Fuel pump relay
Old Apr 24, 2019 | 12:31 PM
jag-reflex's Avatar
Default Fuel pump relay
So my plan is to change out the fuel pump and filter. If I have it right, to depressurize you pull the relay in the black holder, not the red one. Crank it over and you're ready to go. I tried that but the engine keeps running..and running. No sign of it wanting to quit. What did I miss?
Old Apr 24, 2019 | 02:05 PM
Crackerbuzz's Avatar
I pulled the cables off the pump. Wrapped them in a rag to prevent sparks, then started the engine until she stutters. Then turned it off.
Worked for me.
Craig
Old Apr 24, 2019 | 03:02 PM
orangeblossom's Avatar
Hi Jag-reflex
How long did you let her run for?
Old Apr 24, 2019 | 03:16 PM
jag-reflex's Avatar
A few minutes at least..not long enough?
Old Apr 24, 2019 | 03:26 PM
jag-reflex's Avatar
Worked for me.
Craig
Sure, that would definitely do it, but so should the relay pull..I'm wondering why it doesn't. Push comes to shove i will follow your example, but I'd rather understand the puzzle too.
Old Apr 24, 2019 | 03:32 PM
Maybe you didn't have her running for quite long enough?
Old Apr 24, 2019 | 03:39 PM
jag-reflex's Avatar
Possibly I guess, but i would have thought less than a minute with no pump running. I will give it another go in the morning. ..
Old Apr 24, 2019 | 03:55 PM
Mac Allan's Avatar
You might check if a previous owner or mechanic may have modified the relay circuit as mentioned in this post:
https://www.jaguarforums.com/forum/x...0/#post2058300
Might explain your circumstance.
Old Apr 24, 2019 | 04:05 PM
jag-reflex's Avatar
I have the 16CU so no reason for someone to do that, which doesn't mean it wasn't done of course. I will check that, thanks.
Old Apr 24, 2019 | 08:53 PM
With the Black socket relay pulled, a few seconds is all you will get.
My thoughts:
Someone has bridged the actual Black Block, on the underside, to run that pump whenever the Ignition is ON. Reasons, NO IDEA, other than issues and did so for diagnostics and forgot to remove.
Earthing that Orange wire will only work to run the pump whenever the Ignition is ON, IF the relay is installed, so even with that, pulling the relay will kill the pump.
The relay in the Red socket is the Main relay, and that operates the Pump relay, the ECU, etc etc, so pulling that will NOT start the engine, as the ECU is dead.
Old Apr 25, 2019 | 11:05 AM
jag-reflex's Avatar
Yes. found the jumper wire underneath. thanks Grant
Old Apr 25, 2019 | 02:10 PM
jag-reflex's Avatar
So I swapped out the fuel pump and filter. Popped the relay back in and cranked..no start. Reconnected the jumper wire and fired right up. I'll pick up a new relay next..
Thanks to all who chimed in on this thread.
Edit: new relay fixed it. Stupid jumper wire now in the bin. ta-dum
Bowmanconsult
Jan 8, 2024 02:23 AM
AZ RICH
Jun 12, 2018 01:35 PM
NTL1991
XJ40 ( XJ81 )
Feb 29, 2016 05:56 PM
Saemetric
Dec 5, 2014 05:56 PM
Civicalized
Sep 1, 2011 11:40 PM
