High Beams problems
Hi,
I am in the process of moving and packed all my Jaguar books.
My high beams started to work intermittently and now they do not work at all.
Where should I start looking? As always, I suspect a relay but don't know which one.
Thank you,
Jomo
Thank you,
Jomo
it’s not a simple relay. If you search the forum for that part number you will find a lot of good info.
I easily opened up the module tonight and it looks brand new inside. Both relays do work. I checked the resistors and they too are fine. I could not check the diodes or capacitor--although the capacitor did not seem to have any leaks. I did check using a meter for cold solders. That is, I checked for continuity from the solder to the part that was soldered. All seemed fine there. Does this method work that I used?
I am having my doubts that this module is bad.
Jomo
Could you share any specific info that might help someone else in the future?
