Let there be light!
Old Apr 23, 2013 | 04:02 PM
Steve M's Avatar
Default Let there be light!
Anybody know where the headlight dipped beam inhibitor relay is located on an '86 V12 Cabby? Not the big silver one on the left of the engine bay; I've replaced that and still get nothing on dipped beam.
On full beam all four lights illuminate but diddly squat on dipped.
Old Apr 23, 2013 | 04:24 PM
Doug's Avatar
Can't say I've ever heard of one. Are you sure such a thing exists?
Then again such a relay might not have been used on USA cars so maybe I'm just not familiar with it.
Old Apr 24, 2013 | 01:16 AM
Greg in France's Avatar
Steve, I do not know where, but somewhere under the dash there is a relay as well as the one in the front LHS engine bay under the cover. When I switch my lights main/dip and back, there is a huge clonk clearly audible in the cabin.
Do you hear anything from the drivers seat when you switch between beams?
Greg
Old Apr 24, 2013 | 01:44 PM
Steve M's Avatar
There is a loud clunk every time that I go near the car but that is usually the sound of my wallet hitting the ground and exploding under the strain!
Yes, there is a clunk from somewhere near the dashboard; one of captainjaguarscathouse many, many diagrams clearly shows a dipped beam inhibitor relay as well as the main headlamp relay. Now i just need to find it and replace it.
Old Apr 24, 2013 | 05:20 PM
anjum's Avatar
Might be a problem with the lightswitch rather tha the relay but wouldn't expect it to operate the relay/inhibitor switch either.
I had some issues with the headlight relay but were they fixed withe replacing the relay. Are the fuses ok? I seem to remember having some issue with them. The fuses were intact but the contacts had obviously got contaminated.
Old Apr 24, 2013 | 07:34 PM
Doug's Avatar
Which diagram?
What exactly does a headlight inhibitor relay do, anyway?
The curiosity is killing me!
Old Apr 24, 2013 | 08:07 PM
Doug's Avatar
Found some mention of it here, mostly towards the end, section 86A133 and 134, but elsewhere, too
http://www.captainjaguarscathouse.co...&%20Wiring.pdf
One diagram shows it on the RH underdash panel between the rear demist timer and the ignition load relay.
Still curious as to what it does. Looking at the diagrams there seems to be a tie-in with the rear fog lamps. Is that right?
Old Apr 25, 2013 | 01:31 AM
Could be Doug, when the rear guards are on, you cannot get main beam.
greg
Old Apr 25, 2013 | 10:47 AM
Peel86XJS's Avatar
Try this link to see if it has the information you are looking for. 1985 Jaguar XJS Fuse Box Diagram » Auto Fuse Box Diagram
Old Apr 25, 2013 | 11:15 AM
Doug's Avatar
Right! That's the diagram that shows the inhibit relay located between the rear demist timer ad the ignition load relay.
Old Apr 25, 2013 | 02:19 PM
Steve M's Avatar
Thanks guys, I'll have a poke around under there when I get home.
Old Apr 26, 2013 | 06:46 AM
MustangSix's Avatar
I believe the inhibit relay prevents the fog lights from coming on when the high beams are engaged.
On my 83 there is an additional headlamp fuse box located on the left side fenderwell under a small rectangular plastic cover. It has fuses that protect the high and low beam circuits. If you have high beams but not low, the fuses may be blown or corroded. The fuses are mentioned on page 86-52 of the manual above.
Old Apr 26, 2013 | 12:09 PM
Steve M's Avatar
I put all new fuses in as the first step so that shouldn't be the problem.
Managed to drop the lid down somewhere completely inaccessible at the same time so I'll have to try and fish that before it melts on the exhaust.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
