I put new switches and changed the relay behind the glove box, and my passenger window still works once, then stops, as if there is a bad relay. I've cleaned the brushes on the motor, works back and forth when out of door (no load). Is there another relay...one for driver motor and one for passenger? If so, where is the other one? Driver side works fine.
did the window get stuck half way down? Then never works again? Does it make it the whole way down?
Waaaaaay back, before computers and Forums, my Series cars had similar, and I found the small wheels on the regulator inside the channel, were failing to rotate, old age. Jamming the whole shooting match.
Same with the XJS, mainly the Red one.
Took the old wheel to the hardware store, looked in the "sliding door" section, they had staff that knew what they were doing in those days, and found what I wanted. OK they were Blue in colour, the original were White, The car had no idea.
Can I just say that that is about the most beautiful XJS I've ever seen? This is very close to the look I'm going for with my own car, except I am keeping the chrome blades and deleting the tubes for the bumper shocks.
