Removing the AC evaporator
Old Dec 14, 2011 | 09:21 PM
robinlarry's Avatar
Default Removing the AC evaporator
Any suggestions on how the access the AC evaporator? I've removed the center console, glovebox, and radio. The manual I have is very sketchy. It says I need to remove the fascia (dash). Is that really necessary and if so, how do you do it?
Old Dec 16, 2011 | 10:56 PM
robinlarry's Avatar
My service manual cd says that 76.46.01 shows how tgo remove the fascia. Unfortunateoy, the disk doesn't include that operation. Anyone have a copy?
Old Dec 16, 2011 | 11:23 PM
warrjon's Avatar
I have a hard copy if no one comes up with a copy before Monday I'll take it work and scan it. My MFC is no-op at the moment.
cheers
Warren
Old Dec 17, 2011 | 07:24 AM
robinlarry's Avatar
THanks Warren. I've removed the two bolts on the bottom of the outside of the dash. Started removing the instrument panel. I just can't tell from the parts manual whether there are other bolts in there yet.
Old Dec 17, 2011 | 08:41 AM
motorcarman's Avatar
The last one I did was a 16 Hour Job. YES the entire 'dash' to the bulkhead must be removed to gain access to the climate control box.
Pinch the heater hoses and plug the metal line to prevent coolant from spilling into the cabin when the 'box' is hauled out the passenger door.
bob gauff
Old Dec 17, 2011 | 03:51 PM
robinlarry's Avatar
Default Removing dash
Well, I found the top bolts ... dash is loose and ready to come out. '
Did you have to drop the steering wheel to pull the instrument panel out to make room to get the dash out?
Old Dec 17, 2011 | 04:23 PM
warrjon's Avatar
You need to remove the steering wheel. Here is an extract from the ROM
1 Remove pinch bolt securing steering wheel and adjuster mechanism to upper column
2 Slacken locknut and allen screw adjacent to pinch bolt.
3 Remove steering wheel and adjuster from upper column.
cheers
Warren
Old Dec 18, 2011 | 07:51 AM
robinlarry's Avatar
It's out. No mess since the coolant was drained from the engine already.
Old Dec 18, 2011 | 02:27 PM
warrjon's Avatar
As promised
File Type: pdf
Old Dec 19, 2011 | 12:58 PM
xjs40l's Avatar
Took me 19 hours for the job. Much joy and many photo's and plastic baggies.
While you are in there check ALL of the vacuum lines and the vacuum valves. Use this opportunity to repair/replace/retrofit what you can while you have the dash disassembled.
Old Jun 20, 2021 | 12:07 PM
Magna1969's Avatar
Originally Posted by warrjon
As promised
What manual are you using the one i have is terrable!!
Old Jun 21, 2021 | 09:37 AM
Dukejag's Avatar
Post some pictures, interested to see how it looks with the dash out etc,
Good work!
What is the plan for the box?
Old Jun 21, 2021 | 11:42 AM
ptjs1's Avatar
It's a pretty daunting job both to take out, but especially to put it all back! I once helped a colleague do it on a 6 litre. It made me hope I would never have to do it on my car!
Here's a pic I found of a RHD HE car with the dash and aircon out. Be afraid, be very afraid!
Paul
Old Jun 21, 2021 | 03:40 PM
mghirsch's Avatar
I am reassembling mine. !4 months into a 2 week job. (Work, too hot in the garage, rotator cuff repair). Good luck.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Russ Graber
Feb 23, 2019 11:59 AM
Saturbo
Sep 8, 2015 07:35 PM
