Replacement brake accumulator
Old Mar 14, 2019 | 12:19 PM
kansanbrit's Avatar
Default Replacement brake accumulator
I couldn't find the original part for my 1994 XJS 4.0, at a reasonable price, so thought I would look at alternatives. Ordered a Bosch unit as fitted to AMG Mercs and Maybachs. It is a little smaller but screwed straight in. Took 32 seconds to charge initially and takes 23 brake pumps to empty it so I think it will work just fine. $85 Ebay.
Old Mar 14, 2019 | 03:23 PM
Brewtech's Avatar
Cool, Keep us posted. I just replaced one on my xj40 and it cost me 200 or so from Welsch Ent
Old Mar 14, 2019 | 10:43 PM
carsnplanes's Avatar
I have a vacuum booster system. Wgat year was the accumulator done away with. You say yours is a 94. My 95 has vacuum booster.
Old Mar 15, 2019 | 06:13 AM
kansanbrit's Avatar
Default ABS
Does your 95 have ABS?
Old Mar 15, 2019 | 11:23 AM
ptjs1's Avatar
kansanbrit,
Thanks for the info. It's always useful to know of alternative parts.
carsnplanes,
The brake system changed to a traditional servo type at VIN 198335, around November 1994.
Paul
Old Mar 15, 2019 | 11:59 AM
Yes it does. Just common vacuum boosted brake system on 95 and prob 96
Old Mar 15, 2019 | 12:00 PM
Originally Posted by ptjs1
kansanbrit,
carsnplanes,
Paul
Ah, good to know and as I thought. My VIN is 199XXX
Old Mar 27, 2019 | 06:37 PM
kansanbrit's Avatar
Default Update
Still working fine. Amazingly no bleeding was necessary.
Old Mar 28, 2019 | 03:09 PM
orangeblossom's Avatar
Hi Kansanbrit
What sort of Tool did you use to unscrew the Accumulator, as I am going to put a new one on my Car 'Cherry Blossom'
How much of a problem was it to unscrew?
Old Mar 29, 2019 | 09:45 AM
kansanbrit's Avatar
I used an allen key socket with ratchet and held the assembly from twisting by using a G clamp. Once it's held solid it just needs a bit of force to break it loose.
Old Mar 29, 2019 | 11:19 AM
Hi Kansanbrit
Many Thanks
I did my Car Today but getting the Ball unscrewed was a bit of a Nightmare!
Old Oct 30, 2022 | 05:37 PM
MSGGrunt's Avatar
Care to weigh in with any longer-term issues with this accumulator? My 1994 XJS V12 is in need of a new one and finding a less expensive alternative would be nice.
Old Oct 30, 2022 | 06:19 PM
71 MKIV's Avatar
you could also use this
from a 98 to 03 Cadillac. Goes the other way, next size up, but still fits and under a 100 bucks.
I have found that they are all over the agri machine business, combines and harversters and such. If you can find a decent industrial hydraulic supply house, they either have or could order one direct from the manufacturer.
Old Oct 31, 2022 | 06:45 AM
uspurs's Avatar
I installed that GM part a couple of years ago on my '94 V12 and it's been working fine (touch wood, of course&#128513.
Old Oct 31, 2022 | 06:50 AM
MSGGrunt's Avatar
Good to know. I am always a bit apprehensive about using an alternative part unless others can say for certain that it fits and works properly.
Old Oct 31, 2022 | 08:46 AM
kansanbrit's Avatar
It worked perfectly. I eventually exported the car to Paris, France, was working fine when it left me.
Old Oct 31, 2022 | 09:10 AM
MSGGrunt's Avatar
Nothing ventured nothing gained. I just ordered the GM 25676065 accumulator.
Total price with shipping was $107.00
Old Oct 31, 2022 | 10:33 AM
Brewtech's Avatar
I currently have one in my 94 XJS and 94 XJ40
Old Oct 31, 2022 | 08:25 PM
Timeisrelative's Avatar
My 93 works great with the cheaper accumulator. Hasnt missed a beat in 3 yrs i think? Time slips by lol
scrible
Oct 19, 2018 03:07 AM
JayJagJay
May 30, 2018 05:52 PM
So Cal Gato
XJ40 ( XJ81 )
Apr 29, 2013 12:30 PM
WildCat760
Jul 16, 2012 01:28 PM
domer94
XJ40 ( XJ81 )
Nov 21, 2011 02:29 PM
