Security code for radio cassette
Old Sep 30, 2019 | 02:51 AM
MagR's Avatar
Default Security code for radio cassette
Hi
I own a 1990 XJS Coupe but the radio failed and I replaced it with one from an XJS Convertible. The only difference is the replacement is designed to be easily removeable (I think they call it a ****** plate). I think the idea is that convertible owners could leave the hood down and take the radio with them when parked up.
I now want to remove it to touch up the paint slightly. However I can't remember ever being told a security code and the chap who installed it for me is on holiday for two weeks.
Does anyone know whether the convertible radio cassette needs a security code after removal and reinstalling (my original did but that wasn't designed to take out regularly so was an anti theft device).
I don't want to take it out then find I can't get it to work again!
Thanks in advance
Mag (Nottingham, England)
Old Sep 30, 2019 | 05:49 AM
ptjs1's Avatar
Mag,
If it's one of the face-off Jaguar-badged Alpine units fitted to all XJS from early 94, then it doesn't use a security code.
Paul
Old Sep 30, 2019 | 01:36 PM
MagR's Avatar
Thanks Paul
With hindsight I should have realised this - I've got a battery cut off switch which I use when I garage the car and it still never asks me for a code when I switch it back on again.
Regards
Mag
Old Sep 30, 2019 | 11:23 PM
Rivguy's Avatar
Lucky you. My '89 needs the code and I don't think that I will find a source for it. I've tried the "universal" codes without success.
Old Sep 30, 2019 | 11:38 PM
Jagboi64's Avatar
What is the model of your radio? You'll probably have to remove it to read the sticker. If it has a face like the one shown in this post: https://www.jaguarforums.com/forum/x...2/#post1239713
Then feel the sticker and you be able to feel where there is a rectangular cutout in the case. Cut out the sticker in that opening and you will see 6 solder pads for jumpers. Remove all the soldered jumpers and the code is then 1324.
If it's the earlier face like in this post: https://www.jaguarforums.com/forum/x...2/#post1239407 then I can't help you.
Old Oct 2, 2019 | 10:40 AM
ptjs1's Avatar
Rivguy,
Jaguar Heritage still hold the records including key numbers and radio codes for the cars. If you contact them direct and prove ownership, they should be able to help you.
Good luck
Paul
Old Oct 2, 2019 | 01:00 PM
Josh Knight's Avatar
I did this just the other day.
Walk in to a jaguar dealership to the parts department. have the vin number, the radio serial number, your owner ship and a piece of ID. They contact technical, and will be able to get the code for you. Be nice about it because they’re not getting paid for this haha
Old Oct 3, 2019 | 08:11 AM
rgp's Avatar
rgp
Must be what this means on all later 80 cars
mtfd49
Oct 8, 2022 03:25 PM
randyhutson
Apr 12, 2021 09:56 AM
nickg112
Sep 17, 2017 06:06 AM
Terrymadtown
Jun 26, 2012 11:30 AM
howlinowl
Apr 12, 2012 06:02 PM
