smoke coming from one side of the exhaust
Old Mar 18, 2012 | 09:09 PM
calvindoesntknow's Avatar
Default smoke coming from one side of the exhaust
I just started my xjs and i went to warm it up and it is dumping smoke from the drivers side exhaust, and im hearing a ticking noise from the pasengers side of the head, dont know what it is. does anybody know what this could be? fearing it might be a bad head gasket.
Old Mar 18, 2012 | 09:12 PM
Default powersteering cooler upgrade?
anybody have any ideas on where to do this?
Old Mar 18, 2012 | 10:00 PM
M90power's Avatar
sounds like a bad valve seal.
Old Mar 19, 2012 | 12:38 AM
Doug's Avatar
Sounds like coolant is being burned.
How long did you run the engine?
When the engine was pulled did any coolant happen to get into the exhaust pipe? I've had that happen. Takes quite a bit of running before it all burns out....with lots of white vapor billowing in the meantime.
Or....coolant is getting into the combustion chambers
Old Mar 19, 2012 | 04:52 AM
Greg in France's Avatar
Default Power steering cooler upgrade
Maybe you could put a little extra cooler under the front valence, horizontally. This is where, on advice from Grant Francis, I have put an extra gearbox cooler:
It would not need to be nearly as big as the GB cooler, obviously.
The cooler was not yet connected when I tok this photo!
Greg
Old Mar 19, 2012 | 10:48 AM
The oil was clean, and the guy was driving it with a blown headgasket for quite a while plus it sat in my muddy yard in months of rain with the exhaust down. Ill run it today and see if it clears up
Old Mar 21, 2012 | 09:15 AM
i just got a little powersteering cooler similar to that, and i think im going to mount it in the same place
Old Mar 21, 2012 | 09:16 AM
went and bought the headgasket sealer, and got out the valve seals i had and was all ready to fix it, then i started it and no smoke at all, must have been crap in my exhaust from the old engine.
Old Mar 21, 2012 | 07:19 PM
M90power's Avatar
Epic WIN.
Old Mar 21, 2012 | 07:24 PM
M90power's Avatar
Very nice tip. ive been wondering where to put my Trans cooler as well.
D.K
Dec 10, 2023 02:05 AM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
TC Johnson
Sep 2, 2015 09:30 AM
