Sticky accelerator
My ‘94 4.0 AJ6 has a sticky accelerator at the very top. It doesn’t matter if the engine is hot or cold. But it only seems to be sticky when the engine is in. Once I get past the sticky point, which is easiest to do by tapping the pedal, the rest of the accelerator is smooth. I sprayed WD40 all around the accelerator under the hood, to no improvement. I analyzed the pedal itself, and it doesn’t seem to be the issue. It must be under the hood. Thank you for any suggestions.
Curless Auto
May 23, 2017 05:43 PM
drudge
Sep 10, 2014 01:15 AM
