Sticky accelerator
Old May 29, 2023 | 10:15 AM
XJDanny's Avatar
Default Sticky accelerator
My ‘94 4.0 AJ6 has a sticky accelerator at the very top. It doesn’t matter if the engine is hot or cold. But it only seems to be sticky when the engine is in. Once I get past the sticky point, which is easiest to do by tapping the pedal, the rest of the accelerator is smooth. I sprayed WD40 all around the accelerator under the hood, to no improvement. I analyzed the pedal itself, and it doesn’t seem to be the issue. It must be under the hood. Thank you for any suggestions.
Old May 29, 2023 | 10:36 AM
motorcarman's Avatar
Jaguar addressed the AJ16 engine a few decades ago and the AJ6 throttle is similar.
Old May 29, 2023 | 10:56 AM
XJDanny's Avatar
Thank you. I saw this before, but didn’t think it would apply to the AJ6. I printed the bulletin, and will look into it.
Old May 29, 2023 | 12:55 PM
Clean the bore and set the throttle blade stop a little farther if you need to.
Old May 29, 2023 | 01:56 PM
XJDanny's Avatar
I will. Thank you for helping me!
DocBottster
Jun 16, 2021 02:35 PM
Jonathan Ivgi
Apr 19, 2021 03:50 PM
carsnplanes
Feb 10, 2018 09:10 PM
Curless Auto
May 23, 2017 05:43 PM
drudge
Sep 10, 2014 01:15 AM
