Suggested Battery for a 1990 XJS
Old Mar 2, 2019 | 08:06 PM
mikebaker3's Avatar
Default Suggested Battery for a 1990 XJS
I had been using an Optima Red Top in my 90 XJS. It has had a battery post failure.
What are you using as a suitable battery?
Old Mar 2, 2019 | 08:27 PM
Doug's Avatar
I've had good luck with NAPA batteries. Get the highest amp rating that'll fit in the box. Hopefully on sale that day.
Nothing exotic required
Old Mar 2, 2019 | 11:09 PM
Jagboi64's Avatar
I think it's a group 47. I've always had good luck with Costco batteries if they have a size that fits.
Old Oct 7, 2019 | 07:03 PM
Rescue119's Avatar
Well I'm hoping the battery that's in the xjs I'm picking up this weekend, fingers crossed, is one I can find in Canada. I'm going to try and revive it first though lol. Maybe after 4 years it's ok haha.
Old Oct 7, 2019 | 08:19 PM
Jagboi64's Avatar
I got mine at Canadian Tire. I think Part Source has them too, as well as Princess Auto.
Old Oct 7, 2019 | 08:57 PM
Rescue119's Avatar
What brand?
Old Oct 7, 2019 | 10:07 PM
Jagboi64's Avatar
What brand?
It was the Canadian Tire house brand, but the premium line. Eliminator I think it's called?
Old Oct 8, 2019 | 05:58 AM
Rescue119's Avatar
Ok. I'll bring in the old one anyways if I cant get it revived
Old Mar 2, 2025 | 09:05 PM
redjag1990XJS's Avatar
Default Replaced XJS 1990 Battery
Thought I would respond to this thread should it help anyone. I recently replaced my battery in my 1990 XJS Convertible. I read a lot of conflicting information on the web regarding what battery was the right one and which size battery would fit in the metal battery tray in the trunk.
AutoZone (I’m in the USA) said I needed an AGM 34 battery. For my install I needed the positive terminal to be on the left. AutoZone did not have the battery in stock and I’m not really sure they were still stocking it. I ended up finding it at Batteries Plus. It was the Duracell SLI34AGM Ultra Car and Truck Battery | Platinum AGM | 750CCA | Group Size 34. It was $279. This battery fit just right in the metal battery tray and all is working well.
https://www.batteriesplus.com/produc...Code=VI1430611
The dimensions of the battery were: Weight: 42 lbs, Length: 10.2 in, Width 6.8 in, Height: 7.9 in
I was replacing an ACDelco 24PG which a prior mechanic threw in the car about 4 years ago. This battery never performed well, and I was glad to replace it. It wasn’t the right size. Personally I’m not a fan of GM / AC Delco anything.
As to the whole venting/not venting thing. I checked with my jag mechanic and he said the new batteries do not need to be vented. My prior battery was not vented and there were no issues. I don’t know if they make vented batteries anymore as I couldn’t find any in my research.
This is the new battery installed. Positive terminal on the left. I have the battery tied down with J Bolts and a metal bar across the top. The XJS plastic cover fits nicely over this battery.
This is the new battery installed. Positive terminal on the left. I have the battery tied down with J Bolts and a metal bar across the top (this is not shown in the above picture, but you can see the tie down in the last picture with the old battery). The XJS plastic cover fits nicely over this battery.
The handle on this battery was a huge help with getting this battery in place. It is heavy.
This was the old AC Delco battery that did not work well.
Old Mar 4, 2025 | 07:29 AM
Asdrewq's Avatar
I use this in my V12 coupe (& the exact same brand in all my cars):
YBX5027 Yuasa Silver High Performance Car Battery 12V 65Ah HSB027 HSB013
Yuasa Silver is in my experience pretty much always the maximum spec for any particular sized battery.
hsb013 size fits fine. There's a possibility another size of battery might be a more perfect fit/maximise capacity for available battery tray space, but I trawled all the battery specs I could find & none jumped out.
scarbro2011
Apr 12, 2022 01:19 PM
workworkwork
Oct 4, 2019 09:47 AM
Deglick
Jul 28, 2018 07:31 AM
dutkowsky
Nov 29, 2017 06:43 PM
garyofnyc
Jul 9, 2015 01:09 PM
