Transmission Mount
Old May 9, 2011 | 04:01 PM
kthrash's Avatar
Default Transmission Mount
I have a 1995 XJS 4.0 Automatic Convertible..
How do I tell if the transmission mount is bad? I have a drive line vibe at 60-70+ that is worse while coasting than under load. When under the car the transmission moves up and down rather freely with very little effort.. I have looked and noticed that there are multiple parts/pieces to the transmission mount, how stiff is it supposed to be?
Old May 10, 2011 | 12:43 AM
XJSPaul's Avatar
What is the mileage on the car? I would check the universal joints in the rear axle half shafts. One may be wearing out.
xjsPaul
Old May 10, 2011 | 07:52 AM
Doug's Avatar
I'm not familiar with the specific arrnagment on your car but experience with trans mounts on other Jags is:
- they are all needlessly complex :-)
- they all have more movement than an typical rubber block type of mount
- they are made from soft materials for noise/vibration insulation
- they are sometimes weak/too soft even if they don't appear broken
- when in doubt, replace!
I'd say about 1" of easy movment is typical.
Besides the u-joints already mentioned also check the driveshaft bearing....if your model has one. I'm not sure if it does. It's what secures and isolates the driveshaft from the body of the car. If you have one it'll probably be more towards the rear of the driveshaft.
Old May 10, 2011 | 09:09 AM
newworld's Avatar
Default transmission mount removal/replace
doug can u write a brief how to replace tranny fluid and remove and replace mount safely or if already done link me to it? thanks
Old May 11, 2011 | 12:55 PM
XJSPaul's Avatar
There is a UTube vid showing a change out / repair on a 4L 6Cyl trans mount. They did it by raising the car, supporting the trans, lifting the trans, removed the cross member&trans mount, cleaned-replaced all parts and then replaced everything.
XJS Paul
Old May 11, 2011 | 03:26 PM
kthrash's Avatar
Any idea where the YouTube vid is? I cant find it..
Old May 12, 2011 | 11:01 PM
XJSPaul's Avatar
Default YouTube XJS Trans Mount Repair
Do not Try this it should be #1 of 4 segments on the XJS transmission mount repair
XJSPaul
Old May 12, 2011 | 11:06 PM
XJSPaul's Avatar
Now for the correct You Tube Segments
YouTube - Wheeler Dealers - Jaguar XJS - 1/4
4 segments, one covers the trans mount change out.
XJSPaul
mrplow58
Jan 21, 2024 05:53 AM
knightofgold
Feb 11, 2016 06:03 PM
picard
Oct 12, 2015 11:56 AM
ahunt4
Sep 14, 2015 08:17 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
