Trip computer light bulbs facelift
Old Apr 22, 2018 | 07:56 PM
Time-Pilot's Avatar
Default Trip computer light bulbs facelift
I've been over every post I could find, which is how I was able to extract the bulbs from the trip computer. But now I'm stumped. I removed this "fixture" that the bulb appears to be soldered into.
When I found the part number for the bulb I found "LHD5180AA" which goes to a bulb that looks nothing like what I have removed.
https://www.terrysjag.com/SEARCH.html?Search=LHD5180AA
And before anyone asks, no LED's please I despise them. I just want to replace the original bulbs.
Old Apr 23, 2018 | 01:17 AM
Jagboi64's Avatar
The bulbs are integral with the base. It's called a neo wedge bulb and come in different sizes that start with T, such as T3, T4 etc.
I'm sure an internet search will turn up a chart of sizes and you can compare to your existing bulb. They are fairly common in the auto industry for switch and dash lighting.
Old Apr 23, 2018 | 07:14 AM
Vee's Avatar
Vee
Neo Wedge T5
I have a post about installing LEDs and then inserting a “Saffron” light gel (from a theatrical lighting store) to return the color to its stock Aqua color.
I hated the way the incandescents bake the trip computer. When driving at night, hold your finger on the screen for 10 seconds, I doubt you’ll be able to do it. It gets hot!
The shift selector light also runs hot enough to melt plastic. (Open that assembly up and you’ll see some melted plastic). I changed that out to LED and added the same gel filter to correct the color.
Old Apr 23, 2018 | 12:44 PM
Time-Pilot's Avatar
Got a pack of these for the clock:
https://www.ebay.com/itm/6Pcs-T5-T4-...eaed%7Ciid%3A1
They are listed as 12mm which is exactly what mine measured.
Old Apr 23, 2018 | 10:20 PM
RonaldP's Avatar
The LEDs cut down on the heat in the display. https://www.superbrightleds.com/more.../Photos&Videos
Old Apr 24, 2018 | 06:00 AM
Vee's Avatar
Vee
Originally Posted by RonaldP
The LEDs eliminate the heat in the display. https://www.superbrightleds.com/more.../Photos&Videos
Fixed. Eliminating the heat will undoubtedly prolong the life of these ancient computers.
Old May 8, 2018 | 06:52 PM
paulZ's Avatar
I found an X-300 in a Upull it yard. I now have a dozen or so of these things.
Old May 9, 2018 | 06:16 AM
Vee's Avatar
Vee
Don’t tell me you came across several trip computers...
Old May 10, 2018 | 01:13 PM
paulZ's Avatar
X-300 Trip computer?
I am ignorant of your Jag model. This is the chip from an X-300
Old May 20, 2018 | 10:12 PM
Time-Pilot's Avatar
All done.
Vee
Dec 7, 2013 02:56 PM
Vee
Jul 20, 2013 03:12 PM
priest2705
Mar 4, 2011 09:47 AM
frombenz2jag
Jan 1, 2008 03:09 PM
