V-12 Jaguar Exhaust video Magnaflow muffler
Old Jan 20, 2016 | 06:47 AM
bullittandy's Avatar
Default V-12 Jaguar Exhaust video Magnaflow muffler
Thought I'd create a new thread for future searchers looking for exhaust options.
My car has gutted cats, 4" round Magnaflow mufflers in center position and resonator tips (glass packed) in rear. Pipes run under differential.
It is loud but despite it being loud, with a slight drone at 1500 RPM it sounds fantastic.
But, I'm going to add a resonator behind the muffler to knock out the drone.
(FYI-the reason for this muffler choice was that I originally planned to mount in rear position but then changed my tip style after I had the mufflers and I couldn't use these tips with the muffler mounted in rear. I could've exchanged the mufflers for larger ones that fit center position but I rolled the dice on the sound. With exhaust, you never really know until you try it)
https://vimeo.com/152356512
Old Jan 20, 2016 | 08:31 AM
Doug's Avatar
Sounds great !
Old Jan 21, 2016 | 06:01 PM
ronbros's Avatar
i agree sounds GREAT !
now if i could only figure out how to post my Vid of V12 sound, it wont stay loading clicks off, tried it 3 times, some reason my Vids wont go thru!, stills are fine. darn.
Old Jan 21, 2016 | 08:37 PM
superchargedtr6's Avatar
It does sound good. Thanks for the tip!
Old Jan 21, 2016 | 08:43 PM
JTsmks's Avatar
What size pipe did you run from the cats back?
Old Jan 22, 2016 | 04:45 AM
2" pipe all the way back. Installer slightly crushed the pipe where it goes under the differential to add some ground clearance. I've also subsequently added two Walker 4" diameter resonators behind the mufflers. I will post up a new video but the difference in volume is slight. The resonators took out some rasp and also knocked down a drone at 1500 RPM.
Interesting side note: The guy that built the exhaust is a perfectionist. When I cut 20" of pipe out of the exhaust the front and rear sections didn't move AT ALL. I could believe how well bent balanced/supported it was. He has a 4.9 star rating on 30 reviews on Google.
Old Jan 22, 2016 | 06:53 AM
JTsmks's Avatar
Sorry to be a pest BUT would you happen to have the model number of the mufflers and tips?
Old Jan 22, 2016 | 10:23 AM
Old Jan 23, 2016 | 03:00 AM
Greg in France's Avatar
Andy
Do you have any closeup photos of the exhaust on the car and also the fixings your specialist used, please?
Greg
Old Jan 23, 2016 | 09:50 AM
Daim's Avatar
Sounds neat, but I miss some "omph". Some crackling... Some "bommmmm bom bom bommm"
Old Jan 23, 2016 | 06:12 PM
Andy
Greg
Here ya go:Name:  IMG_3294.jpg
Please note that this is my work after the exhaust was complete. I added the resonator behind the muffler and mucked up the original work a little.
Old Jan 24, 2016 | 01:03 PM
mike90's Avatar
Wow, great job!
NowthatswhatImtalkinabout!
Having played around with the exhaust on my '90 so much that I don't really care to delve into it again, I have to say that I am amazed at what leaving the gutted cats does to the sound! I run AJ6 TT's, and I have tried the glass packs and chambered and turbos and on and on and on some more. I have a pretty nice sound right now, but I am quite made up over what you've got there with such a simple setup.
Nicely done!
Larry Louton
Feb 10, 2017 07:44 PM
RobbyHughes
Mar 8, 2016 07:46 AM
Rostman
Dec 29, 2015 03:20 PM
RobbyHughes
UK & Eire
Dec 21, 2015 07:52 AM
