V12 6.0 idling high
Old Nov 7, 2011 | 12:53 AM
jaguarlars's Avatar
Default V12 6.0 idling high
Hello. New member here from Sweden!
I have probolem with 6.0L V12. When cold engine is idling about 1600rpm. After around 5 minutes it´s normal and about 750rpm. Is it possible to adjust the idle when engine is cold?
Old Nov 7, 2011 | 11:44 AM
M90power's Avatar
its called open loop. as far as i know theres no way to adjust it.
Old Nov 10, 2011 | 02:54 PM
xjrguy's Avatar
Sounds like a failed Extra Air Valve to me. The large screw/bolt on it is used to adjust the warm idle, the cold idle is controlled by the valve.
Cheers,
Old Nov 14, 2011 | 05:27 AM
jaguarlars's Avatar
I have replaced the valve with a new one but it doesn´t help. Well car runs perfect when hot so maybe I should be satisfied!
Old Nov 14, 2011 | 01:17 PM
kev's xjsc's Avatar
The issue you discribe is the cold engine boost from the Auxiliary
Air Valve. It sounds like it is working just as it is meant to.
If you do not want it I could use it! Mine is stuck and I idle 2000 RPM and it does not come down ever.
Old Nov 14, 2011 | 01:20 PM
kev's xjsc's Avatar
After reading your post again it looks like you might have 2 that work,
what would you want for one of them?
Old Nov 21, 2011 | 09:54 PM
bigwiki's Avatar
Does the V12 has idle control valve to control the idling?
Old Dec 15, 2011 | 03:59 AM
jaguarlars's Avatar
Sorry, but my customer took it with him. I might be able to get one more. drop me a mail if you are still interested!
1100me
Jul 24, 2023 06:10 PM
JWheeler
Nov 22, 2019 08:28 AM
Mac Allan
Oct 27, 2015 04:49 AM
ccfulton
Sep 20, 2015 05:15 PM
1100me
Sep 7, 2015 06:26 AM
