Wiper Plug
Old Nov 6, 2021 | 07:53 PM
MrAndersonGCC's Avatar
Default Wiper Plug
1983 XJS. Trying to diagnose my wipers and want to test the motor. To which one of these holes in the plug should I send 12V to test? Second picture below: is one of these the wiper delay relay? Thanks
Old Nov 7, 2021 | 12:50 AM
Greg in France's Avatar
The wiper relay is below the dash, inside the car.
Old Nov 7, 2021 | 12:51 AM
drivers side or passenger? Any idea what it would look like on an 83?
Old Nov 7, 2021 | 09:29 AM
BenKenobi's Avatar
Passenger side behind glove box is what I understand, I believe it is blue in colour.
I haven't yet worked out the pins fully but several of them are +12V - at least 3 of them my guess would be the large pins - these are Park (Red), Fast (Yellow), Run (Green) and Normal (Blue), the ground is white, I'm not entirely sure what the 'run' pin is for. There are two pins that I don't think do anything.
Old Nov 7, 2021 | 10:58 AM
andegra's Avatar
Default Wiper circuit
Attached a schematic that might hjelp younout.
Old Nov 7, 2021 | 04:51 PM
Thanks! The schematic describes having the ignition switched “on” - is this saying the engine must be running for the wipers to work?
Old Nov 7, 2021 | 05:19 PM
garethashenden's Avatar
Effectively, yes. When you turn the car off the wipers stop where they are. The engine doesn't need to be running to test it though, just turn the key to position 2 without starting the engine.
Old Nov 8, 2021 | 09:04 PM
Default Interesting update
Much to my pleasure, I was surprised to see that my 83 has an Electrolux assembly.
Even better: I was able to make it turn by routing 12v directly into the plug (albeit after manually moving the arms a bit, which may have loosened things up).
Here’s my question: based on this video I took of the motor turning in slow mode, is it worth me cracking this open to regrease? Thanks
Old Nov 8, 2021 | 09:42 PM
Default Testing relay continuity
See other video below. My understanding is that there should be no continuity between plugs 1 & 4 unless power is routed to plug 3 (2 being ground).
My multimeter beeps like there’s continuity between 1 & 4, it starts reading at about 0.5 ohms but quickly drops to 0.0. Is this proper behavior or a bad relay?
If the relay is good that only leaves the wiper stalk.
https://youtube.com/shorts/d0UJvScksNE?feature=share
Old Nov 8, 2021 | 09:48 PM
Sorry for a third post, but for easy reference I’m basing my relay test on this:
jomo
Sep 3, 2021 03:57 AM
RMerkley
Aug 19, 2021 07:04 PM
Per Greibe Soerensen
Jan 30, 2019 05:14 PM
nebelfuerst
Feb 6, 2013 06:10 AM
Lanny Edgeman
Jan 8, 2012 12:58 PM
