xjs '95 brakes unreliable and dangerous now
Old Jan 30, 2020 | 11:31 AM
pimmow's Avatar
Default xjs '95 brakes unreliable and dangerous now
Hi my brakes are starting to become very dangerous. i had problems with the abs activating during normal breaking, and as a result the steering wheel would pull to the left. i could hear the abs pump pulsating. my mechanic cleaned all wheel sensors, they were pretty dirty, and checked the wiring. sometimes the abs light would come on, but also went out again. it now evolved in the situation that sometimes, when i break, the pedal is hard, and when i brake harder, while hearing the abs pump work, the pedal would suddenly go deeper as if something had been stuck under it and slipped away. today this happened, i wanted to break on the end of a highway exit, but it was harder then normal. when i pushed it further, suddenly it 'jumped' further, the abs was pulsating and the steering wheel pulled to the left sharply... very dangerous and my heartbeat went crazy...! the abs light came on, and when i tested it on a slippery road i noticed that the abs was not working anymore, and the problem also didnt happen anymore when the light was on.
i hope someone can help me here....! thanx, Pim
Old Jan 30, 2020 | 12:21 PM
ptjs1's Avatar
pimmow,
I would take a deep breath and take the ABS valve block apart. The symptoms you describe seem to imply that one wheel is acting under ABS conditions whilst the other wheel isn't. That's typical valve block inconsistency. There are quite a few threads here discussing the valve block and also a number of members who have taken the block apart. The typical problems are dirty, corroded valves and an ageing printed circuit.
Do a search on the Forum and you'll find a variety of threads. Read them all and then dive in.
Good luck
Paul
Old Jan 30, 2020 | 02:51 PM
Vee's Avatar
Vee
Do you know if you have the Teves III or IV brake system?
If you don't know, you either have a ball shaped accumulator on the passengers's side of the engine, up by the firewall, or you have a large cylindrical accumulator on the drivers side of the engine bay, also by the firewall.
Old Jan 30, 2020 | 03:49 PM
pimmow's Avatar
Hi Vee, it's the latest system, so teves 4 then? it has the black cilinder on top of the abs module.
thanx, pim
Old Jan 30, 2020 | 04:27 PM
ptjs1's Avatar
Good question Vee,
I was guessing (incorrectly) that it was the earlier system with the problematic valve block.
Pimmow,
Apols, I've misled you. The later systems are not renown for the problems now being experienced by the earlier systems.
Paul
Old Jan 31, 2020 | 02:03 AM
orangeblossom's Avatar
Hi pimmow
Could it be the Vacuum Tube is Blocked?
Old Jan 31, 2020 | 02:06 AM
pimmow's Avatar
Originally Posted by orangeblossom
Hi pimmow
sorry, i dont know which one you mean? Where is it? Thanx
Old Jan 31, 2020 | 03:56 AM
Hi pimmow
I've got a car the same as yours but She's all covered up at the moment, so I cannot get to the engine in order to take a look but on my V12 the Brake Servo on the side with the Pedal Box has a Vacuum Pipe connected to the inlet manifold
Not sure about my 95 but wouldn't be surprised if she has got one, so maybe someone will know
Old Jan 31, 2020 | 08:43 AM
Vee's Avatar
Vee
Is the ABS light blinking, or just on steady?
The only common issue to this brake system is that the sensors get dirty and lose their ability to read the wheel. My front passengers wheel sets a code every now and then. A cleaning usually takes care of it for awhile.
It's difficult to access. Anytime you're servicing the suspension there, it would be worth it to go in there and clean it out. If you pull the brake rotor, you'll have an easy go of it as well.
Ultimately when the ABS decides it's not working, you have a normally, non-ABS brake system. Still completely safe, just not enhanced with the ABS benefits.
Old Jan 31, 2020 | 09:24 AM
Steve M's Avatar
I had similar symptoms with a strong pull to the left and it turned out to be a collapsed caliper hose on the other side.
Replaced bot with a pair of braided hoses and the problem went away.
Old Feb 1, 2020 | 04:34 AM
pimmow's Avatar
i think this is not the issue since it only happens sometimes; and at the same time the abs activates without reason. When the abs light is on, there are no issues.
thanx, pim
Old Feb 1, 2020 | 04:37 AM
pimmow's Avatar
hi already cleaned all sensors without succes...thanx, pim
the abs light is on constantly now, and the problem disappeared. Before it was off. And it acted very dangerous, as i described.
could it be the issue with the abs module solder contacts being broken? Not sure if it also was the issue with these years, but ive read several messages about this.
thanx, pim
Old Feb 1, 2020 | 04:38 AM
pimmow's Avatar
thanx, pim
Old Feb 1, 2020 | 04:30 PM
Vee's Avatar
Vee
Odd. I'd love to get that code pulled and see what the ABS is telling you is wrong. Unfortunately, to pull the ABS codes, you'll need a Jag-specialized reader....
Old Feb 2, 2020 | 06:14 AM
Hi pimmow
Check all the Fuses under the Passenger Kneepads (UK) Car maybe the one for the ABS is either Blown or Corroded and not making proper Contact
bullittandy
Mar 3, 2017 04:44 PM
Saspc
May 26, 2016 05:58 PM
Sarc
Sep 29, 2015 08:28 PM
orangeblossom
May 18, 2015 07:43 AM
NW1996
Jan 30, 2014 04:22 PM
