150 XK bluetooth cell phone music
Old Oct 17, 2017 | 12:00 PM
danveenstra's Avatar
Default 150 XK bluetooth cell phone music
I have been trying to find the other post about this but I have been unsuccessful. I wanted to post this as it is important to Jag 150 music lovers.
I have a 2007 XK Convertible and wanted to play my IPhone 6 plus music through my car speaker system. I got a local quote of around $500 to accomplish this task which involved removing the radio and hard wiring a component.
I saw a posting (somewhere) about the CHGeek Bluetooth FM Transmitter with Dual USB Ports. It's only about $20. It's a rather simple procedure to getting it to work. All you do is:
1) Plug it into a power outlet (cigarette lighter)
2) Pair the Transmitter with your phone
3) Turn your transmitter to an FM station and match that station on your car radio. Done
There are other things you can do which are explained in the Users Guide. I only use it for playing music. I am posting pictures in this posting as well as a copy of their User Guide.
Attached Thumbnails 150 XK bluetooth cell phone music-a1.jpg   150 XK bluetooth cell phone music-a2.jpg   150 XK bluetooth cell phone music-c.jpg   150 XK bluetooth cell phone music-b1.jpg   150 XK bluetooth cell phone music-guide-page-front.jpg
150 XK bluetooth cell phone music-guide-page-01-02.jpg   150 XK bluetooth cell phone music-guide-page-03-04.jpg   150 XK bluetooth cell phone music-guide-page-05-06.jpg   150 XK bluetooth cell phone music-guide-page-07-08.jpg   150 XK bluetooth cell phone music-guide-page-09.jpg
Old Oct 17, 2017 | 12:47 PM
Cee Jay's Avatar
OR, put all your songs on a USB stick and leave it in the USB port forever. Much cleaner sound that way. I have about 9,000 songs on mine.
Old Oct 17, 2017 | 03:41 PM
shemp's Avatar
Doesn't it start on the first song every time you start the car?
Old Oct 17, 2017 | 03:44 PM
Mufc's Avatar
Another option is to buy an old ipod from Ebay, I got one for $40.00 download your songs from itunes to the ipod and leave it plugged into the ipod cable that comes with the car. Keeps the ipod charged and sounds as it should. When you download new songs to your phone or Ipad, they will sync automatically to the ipod when within wifi range.
Old Oct 17, 2017 | 03:46 PM
shemp's Avatar
Personally, i like the BT thru the phone because then you can get to Youtube, Pandora,etc if needed. There are many ways to skin this cat
Old Oct 17, 2017 | 04:06 PM
Cee Jay's Avatar
I push the "Next" button once as it's on Shuffle.
Old Oct 17, 2017 | 04:23 PM
shemp's Avatar
ah, yes. I bet you know the first three or four notes of that first song pretty well by now
Old Oct 17, 2017 | 05:45 PM
Tervuren's Avatar
In my car it generally starts with what it was last playing with the USB.
The I-pod is the one that has a stuck first song sometimes, but I'm taking it in and out. The USB I pretty much leave.
I'm the kind of person that can put an album on repeat though, which is I think rare. I also use the song repeat button too.
Old Oct 17, 2017 | 07:38 PM
Stuart S's Avatar
I use an ancient iPod Nano 5 (?) that I dedicated to music use only because it works with the steering wheel controls to change tracks and volume and displays on the infotainment screen. Integrated IPod connectivity became standard beginning with the 2009 model year (4.2L), but could be retrofitted to earlier years with the Audio Connectivity Module, a dealer-installed accessorry. I have no need for Bluetooth music because my iPod does it all. I have it connected with a Schosche adapter that enables it to simultaneously play and charge. It resides in the center arm rest.
Old Oct 31, 2017 | 04:45 PM
VinceG's Avatar
I bought a Roidmi Bluetooth to FM transmitter for $25.00 (cut n paste below). Works great! I took the fuse out of the power antenna (behind the rear middle seat divider <fuse F4>) cuz the extended antenna looks ridiculous. It limits the weak signal interference and sounds great! Only the strong signals come in. But I use my iTunes app on my iPhone 6s almost elusively.
Amazon Amazon
Old Oct 31, 2017 | 05:59 PM
Cee Jay's Avatar
Yeah, I'd be elusive if I was saddled with any iphone myself. Hide in my basement, probably.
Old Oct 31, 2017 | 07:10 PM
Stuart S's Avatar
I found my old thread from 2011 and thought it might be of interest. It discusses the original and updated OEM Jaguar iPod cables and compatibility of later iPod models: https://www.jaguarforums.com/forum/x...nano-6g-50122/
Old Oct 31, 2017 | 08:47 PM
amcdonal86's Avatar
I noticed when I play a saved voicemail, it will play through the speakers as if it is a phone call. Surely there must be a way to make the car recognize Spotify, etc, as a phone call? Someone please develop an app!
Old Oct 31, 2017 | 09:38 PM
knewman's Avatar
Such apps exist already (example: https://audiooverhfp.com/about-audio...-a2dp-blocker/) however this is highly undesirable and can possibly damage your sound system if music is played at high levels. Bluetooth HFP isn't intended for high fidelity audio and the spec only supports 16khz mono.
It'd be like running that sweet 5.0 V8 on leaded petroleum w/ twigs and dirt mixed in. You're better off loading up a USB stick to live in the center console. Plus the system will show what song is playing if your files are tagged properly.
Old Oct 31, 2017 | 09:42 PM
Tervuren's Avatar
On my 2009, if I do not change the source, it will start playback from last point of use.
If I change the source away from USB, then go back to USB, it will play the first song of the first artist of the first album when swapped to USB from another source, such as CD, radio, i-pod, etc.
So in my case, the first band on my USB by alphabetical order is After Forever, first album by that band in alphabetical order is a self titled album, and the first song(by track number) then gets played.
I supposed I could use this knowledge to my advantage, by creating a file with artist/album/song data that would want to be there if I hit the USB source from another source.
Old Nov 1, 2017 | 07:53 AM
Ric in RVA's Avatar
What I used in X300 with its stone age radio....
https://www.jaguarforums.com/forum/g...lution-191176/
Super easy to wire up. Basically if you can get to the back of the radio and locate a switched positive wire you are done.
Old Nov 1, 2017 | 09:11 AM
shemp's Avatar
Good point. Im sure it's possible in an app but probably not much motivation to create one. If I were capable I would do it!
Old Jan 30, 2020 | 07:21 AM
Richard Powell's Avatar
Hi. I am about to buy an XK 2009 Portfolio. I regularly use Spotify. I had presumed that my phone would just connect and play music but obviously I'm wrong there. Would one of these units allow me to play Spotify through the car?
Old Jan 30, 2020 | 09:11 AM
DGL's Avatar
DGL
Don't go through a low quality FM transmitter use a Bovee1000 with direct connection through the ipod port in the console--no degradation in quality. There are a few members working on android box connections to upgrade the infortainment system. Rhy's Morgan's is working on implementing this through using software to stiff out all of the necessary codes from the CANBUS and communication channels. The other way is a work around through a GVIF device. Either way once successful this will update the infortainment system to everything an android box has to offer including bluetooth streaming.
Old Jan 30, 2020 | 11:24 AM
Sean W's Avatar
THIs is what you want if you have the 30 pin connector in your car. Plug it in, activate it via BT on your phone.
Amazon Amazon
