2007 XK 4.2 Timing Chain???
Old Oct 1, 2021 | 01:49 AM
Chris77's Avatar
Default 2007 XK 4.2 Timing Chain??? **Panic Over**
That’s a £1 coin for scale (23m diameter)
Found this mangled metal on the drive, and when I started the engine there was a rattle so stopped immediately.
Looks like some kind of guide or bracket. It is stamped “K20” and has “Adamo” in a script font. I have googled and can’t find any definitive part.
I suspect it is associated with the timing chain but can anyone confirm before I book a recovery truck?
That’s a £1 coin for scale (23mm in diameter) Looks like I may need a few more of these!
Last edited by Chris77; Oct 1, 2021 at 04:06 PM. Reason: Panic Over added to title
Old Oct 1, 2021 | 03:06 AM
JagV8's Avatar
The timing chain is entirely inside so for that to be associated with it there would need to be a big hole in the block or somewhere!
Having started the engine there would be MASSES of oil everywhere - which I feel you would have mentioned so don't have.
See if someone knows what it actually is.
Old Oct 1, 2021 | 04:23 AM
JonWat's Avatar
I think you need to open the bonnet, get the engine covers off & have someone start the engine while you try & find out where the rattle is coming from
Old Oct 1, 2021 | 06:10 AM
George05's Avatar
I would not start it , could and would do more damage . Just peek into the oil cap
Old Oct 1, 2021 | 01:35 PM
jahummer's Avatar
Doesn’t look like a part of the car. I would look about the engine compartment and underneath. Could be a pulley or tensioner’s gone off.
Old Oct 1, 2021 | 03:58 PM
Chris77's Avatar
Thanks all for your feedback!
I checked under the bonnet today… no outward sights of the cause of the noise
I decided to try starting it, no sign of any rattle the engine… only a sweet V8 burble.
Not sure what I heard last night….. maybe some leaves got blown up into the engine bay in the high winds. A definite case of paranoia… (not had it long and loving every opportunity to drive it)
Old Oct 1, 2021 | 04:09 PM
Cee Jay's Avatar
That piece flew up from the road and into the fan area and you panicked? I probably would also.
Old Oct 2, 2021 | 08:25 AM
JagV8's Avatar
Thanks for the update.
CaptnJack
Jul 1, 2021 05:16 PM
Skyhawk22
May 4, 2020 06:13 PM
Gom
Mar 13, 2018 09:59 PM
TN8Shooter
Sep 30, 2012 09:16 PM
filoli1993
Dec 17, 2010 01:40 AM
