2007 XK8 Navigation problem
Old Apr 16, 2021 | 06:06 PM
wlmcdougall's Avatar
Default 2007 XK8 Navigation problem
Hi team, I have an issue with my navigation system in that I accessed the hidden menu and stupidly pressed 'update software'. Now my vehicle does not recognise that a nav computer is installed so my questions are:
1. Is mynav computer bricked?
2. Is it a simple fix of just buying another computer from Ebay and installing it or will it need coded?
Thanks in advance,I'm in NZ by the way so main dealerships are scarce.
Cheers Bill
Old Apr 16, 2021 | 06:59 PM
ralphwg's Avatar
Do you have an XK or and XK8? If you have an XK8 you are in the wrong forum, you should be in the X100 forum to get appropriate answers. The first XKs (X150) in the U.S. were 2008 model years. Your listing is confusing. Updating the GPS in the X150 is done by replacing the CD-Rom with a later edition.. The most recent versions that work can be found at Volvo dealerships or maybe Ebay. Anyway there is a search box in the upper right corner of this page where you can type in you question and get some info there. Good luck
Old Apr 16, 2021 | 07:46 PM
My car is a 2007 XK 4.2 (X150) first introduced in 2006.
My post is about accessing the hidden menu and selecting 'update software's which has now stopped my vehicle recognizing the nav computer?
Old Apr 16, 2021 | 07:47 PM
Old Apr 16, 2021 | 08:26 PM
Cee Jay's Avatar
Before anything, try a Hard Reset. Disconnect BOTH main battery cables and touch them together (yes, the battery cables touch) for about ten seconds. Make SURE the battery isn't a part of this procedure.
The windows should then be reset using the factory window reset procedure, and all the other adjustments SHOULD remain as they were.
This may fix it, it may not.
Old Apr 16, 2021 | 09:50 PM
Stuart S's Avatar
Ralph,
The OP's in New Zealand, so the trick using the North American Volvo disk won't work for him. It appears that you made a typo, since the first X150 model year in the US was 2007 (2006 in the UK).
Stuart
P.S. The "propeller blade" in the OP's grille was a design feature of the X150 introductory year only.
Old Apr 16, 2021 | 10:32 PM
u102768's Avatar
We do have Volvo's with Sat Nav here in New Zealand
Old Apr 17, 2021 | 06:47 AM
Stuart S's Avatar
Of course, but the Volvo nav disk for NZ is useful only if the maps are newer than those on the last disk available from Jaguar.
There's a 2017 Volvo disk for Australia, which is newer than the last Jaguar disk from 2013, but I don't know about NZ.
https://www.jaguarforums.com/forum/x...v-disc-191140/
Old Apr 17, 2021 | 07:24 AM
guy's Avatar
guy
greetings all,
The OP is accuate. The software update option selected is there to update the management software on the navigation device. Commonly referred to as ROM. It is not to update maps.
(and incidentally, my 07 was acquired from the dealer in 06)
I’m with Cee Jay on this one. in the event you do not have the Alpine? ROM disk, (I have no knowledge where to source one) I would try the hard reset first. Be certain to clear all memory! (that means don’t just disconnect the battery but actually discharge all components by touching the cables) Then the standard boot process should invoke. I might in fact take a deeper look today... I wonder if I can source the image from Alpine directly...
romello424
Oct 30, 2015 07:51 PM
tmz_99
Sep 2, 2009 06:58 PM
tummms98
Aug 4, 2007 11:25 AM
Oct 14, 2006 11:36 PM
