2011 XKR Metal Clanking from Engine
Old Jul 8, 2021 | 11:16 AM
Peter Ucinski's Avatar
Default 2011 XKR Metal Clanking from Engine
Hi guys,
Before I take my cat to the mechanic and spend big $$$ maybe you can help me... my car has 70k miles, and in last few days I noticed strange noise coming from engine, while running, tried cold start, warm it up, A/C on/off, turning wheel while engine running, but the noise stays the same. I decided to stop driving it to prevent any damage.
here is video sample of the noise.
Old Jul 8, 2021 | 11:26 AM
XJ8JR's Avatar
How's the oil level?
Old Jul 8, 2021 | 11:41 AM
KrazyIvanUSA's Avatar
There was a video a while back of a guy buying a used Jag with what the seller said was an engine knock. Ended up being a very inexpensive and easily replaced part on the Supercharger. I'll see if I can find the video and post it.
Old Jul 8, 2021 | 11:44 AM
Here you go. Sounds exactly like your video:
I linked to the timestamp in the video with the sound, but maybe watch the whole thing for full info.
Old Jul 8, 2021 | 02:09 PM
XJ8JR's Avatar
The supercharger coupler itself is cheap but the labour to swap it out is not. You can DIY at home if you're handy but its still a good amount of work.
Old Jul 8, 2021 | 02:58 PM
Thank you!, I'm sure it will take me longer to find needed tools in my step-father's garage than to fix the engine !
Old Jul 8, 2021 | 03:41 PM
CaptainQ's Avatar
Hello Peter,
Sounds very similar to the prroblem I had with my 2010 XKR - turned out to be the notorious water pump bearing failure (( could see the pulley wobbling really badly when the noise started - the car had only covered 34,000 miles at the time). Stand on the right hand side of the car and look between the hoses - you should be able to see the water pump pulley.with engine running Sometimes these noises, although very frightening, can turn out to be something external. Good luck !
Old Jul 8, 2021 | 04:06 PM
Sean W's Avatar
Watch this thread on removing the S/C. Videos are excellent.
https://www.jaguarforums.com/forum/x...thread-248243/
Old Jul 9, 2021 | 08:51 AM
eddadams53's Avatar
I had a horrible notice with my XK8. I was told it was the water pump. Turned out to be a lose pully. Just tighten 3 bolts, fixed it. Be sure to check the simple stuff like that before dropping any money. Learn from my mistake. Good Luck.
Old Jul 9, 2021 | 09:45 AM
Stuart S's Avatar
Old Jul 23, 2021 | 09:03 AM
Here is update guys, It turned out that the water pump was making that noise, the pulley seems to be loose and hitting the engine block although it was not leaking coolant..... i don't think it can be tightened as there is only one bolt on the water pump pulley, correct me if I'm wrong .....
Im located in USA, where should i get water pump from?
should i go with OEM or aftermarket?
anything else should I order or replaced while I'm there?
Thank you !
Old Jul 23, 2021 | 09:46 AM
Thank you !
Looks like you can get OEM for about $200-$250. I'd go that route. Kind of crazy considering I spent $380 on a damn small piece of plastic interior trim piece...
Here is your part:
https://parts.harperjaguar.com/oem-p...embly-aj813909
The local dealer was ridiculous, so I bought my mirror cover from this same dealer. Shipping was fast and had no issues. I was a bit leary about buying online, but they came through great!
Old Jul 23, 2021 | 09:58 AM
Here is your part:
Yeah Harper jaguar is great ! I've ordered few parts from them, just wondering what else should I order and get replaced while car is disassembled
Old Jul 23, 2021 | 11:42 AM
tmich's Avatar
You are having 5.0 s/c, correct? If it's early model you will have a longer list of parts to replace assuming you want to have the latest iteration of a water pump.
For sure you need these two:
- C2Z18658
- AJ811539
As far as I remember upgrade/update of water system requires:
- C2Z26930
- LR049989 (cannot find Jag number, but this one is the same as in Jag)
Also changing thermostat to water pump hose might not be a stupid thing (again LR code: LR033994)
Hope it helps.
Old Jul 23, 2021 | 01:08 PM
- C2Z18658
- AJ811539
- C2Z26930
Hope it helps.
Man, this is getting more and more expensive lol
thank you for recommendations
Old Jul 23, 2021 | 01:55 PM
tmich's Avatar
Using LR parts is a form of money saving (at least in Europe)
And all you need is available both in Jag and LR
Old Aug 7, 2021 | 08:18 PM
UPDATE:
I turned out that water pump was making that noise, WP pulley was lose, Replaced water pump, belts, hoses and thermostat. all good now!
Old Aug 7, 2021 | 08:57 PM
tberg's Avatar
I just saw this thread and was going to suggest the water pump because I had a similar but even more pronounced noise coming from mine several years ago and was sure it was coming from the supercharger, but it turned out the water pump was wobbling so much it was knocking on the engine. But don't think you're done, I've had five water pumps on my 2010 XKR.
Old Aug 9, 2021 | 08:54 AM
Did you use OEM waterpump or aftermarket?
Old Aug 11, 2021 | 09:56 AM
tberg's Avatar
I believe OEM, tight squeeze and didn't want any surprises.
AlexJag
May 26, 2021 08:49 PM
larueb
Apr 29, 2021 01:05 PM
powerhouse
Sep 19, 2014 03:40 PM
Lenoat702
May 30, 2013 06:51 AM
