Adding a sensor to the front lower valance
Old Dec 17, 2017 | 06:55 AM
TheGuvnr's Avatar
Smile Adding a sensor to the front lower valance
aftre recently damaging the front carbon fibre valance, before I put another one on and do the same thing I was wondering if anyone else has done the same thing. To prevent this from happening again I want to add a sensor at this area and tie into the existing sensor harness from the bumper sensors. Has anyone out there done anything like this thanks
Old Dec 17, 2017 | 09:56 AM
Ranchero50's Avatar
I don't think it's a huge deal. Just find a 12-24 vdc proximity sensor with the range you want and wire the switched leg into an LED on the dash.
It's actually easier to pick a spot on the ground or the vehicle next to you to stop at that gives you a foot of clearance up front. Figure 6' from the side mirror to the bumper lip so stop 7' from the end up the car next to you. Spatial orientation for the win.
Old Dec 17, 2017 | 03:31 PM
TheGuvnr's Avatar
Default Adding a sensor to the front lower valance
thanks for your reply but would it be possible to wire into the sensor wire harness that are connected to the sensors on the bumper your thoughts
Old Dec 17, 2017 | 03:44 PM
kj07xk's Avatar
Kind of doubt that you could 'add' a sensor, since I suspect they are individually addressable, so the car knows where the obstruction is (I don't have front sensors on my XK, but the rear sensors cause the display to show the direction in which you are approaching an object.
That said, you should be able to 're-locate' one of the front center sensors to that lower position. I wouldn't pull out an existing sensor, leaving a hole, but get a replacement sensor, place it where you want it, and then disconnect the donor sensor and wire the new sensor to the donor sensor connector.
Old Dec 17, 2017 | 04:15 PM
TheGuvnr's Avatar
Good idea I never thought of that, I am pretty sure that would work.
Old Dec 17, 2017 | 04:28 PM
Cee Jay's Avatar
Cheap-o sensors are all over Amazon and eBay. You can buy a whole system of four with the indicators for $12. Install them wherever you want.
https://smile.amazon.com/YueYueZou%C...parking+sensor
Old Dec 17, 2017 | 08:56 PM
pwpacp's Avatar
How about a Curb Alert as a suppliment. Mount it, aim it, and calibrate it howerver you want. I'd use the LED option they offer.
Old Dec 23, 2017 | 09:52 PM
sherbercars's Avatar
Ive looked into these in the past ,the one thing I found was the sensors are quite large ,I dont no if a jag sensors would be compatible ? ,the other thing is mounting if you want it to operate say approx a foot away from a parking curb would it pick up the road when travelling ?, My other thoughts are a camera , the problem with that , is you would have to switch it on when parking .
Old Jan 14, 2020 | 06:03 PM
apr1962's Avatar
Is the tow hook location with the P7 grill solved?
thanks
andrew
Old Jan 14, 2020 | 08:57 PM
guy's Avatar
guy
But it would be more aesthetically appealing than those curb feelers... of course, I'm far too egotistical to put those on my car...
Old Jan 29, 2020 | 10:39 AM
WillWiggs's Avatar
Old Feb 1, 2020 | 07:09 AM
Unhingd's Avatar
thanks
andrew
Not yet, but I’m still working on it. I’ve been looking for a local machine shop that’s willing to work with me on this and on converting the OEM shifter to a short-shifter.
iramphal
Aug 28, 2024 10:56 PM
zray
Jan 5, 2019 05:19 AM
Boomer from Boston
Jul 17, 2017 05:32 PM
DevlinC
Feb 15, 2016 03:22 PM
harryco
Nov 3, 2013 07:14 AM
