Amount of ATF behind drain plug?
Old Aug 13, 2021 | 01:05 PM
Speedagent's Avatar
Default Amount of ATF behind drain plug?
Curious and have not found this info through search as it seems nearly every post about ATF includes only removing/replacing the pan and fluid.
Anyone know how much fluid should drain if I were to only pull the drain plug? Also, can anyone confirm torque on the plug? I have seen a couple of different numbers, both being very close to finger right, 8ft/lbs?
Thanks,
SA
Old Aug 13, 2021 | 07:41 PM
guy's Avatar
guy
But the filter is integrated with the pan…
In fact, does it matter how much drains? The fill procedure ensures a rightful volume of fluid in the transmission.
Old Aug 13, 2021 | 08:13 PM
Cee Jay's Avatar
Supposedly about nothing would drain, as the FULL indication is Up To the Fill Hole when at temp. There is no DRAIN plug.
Old Aug 13, 2021 | 08:25 PM
panthera999's Avatar
According to ZF, the listed torque for the plastic transmission pan on the GAHP26 is 8NM, including replacing the o-ring on the plug (good idea, since the o-ring is usually a few years old).
The fill plug torque is 35NM.
The fill amount is determined by a fill process that's temperature related, and filled while running. This sucks because you're reaching past a hot exhaust pipe.
Typically 6-7L are used, but the exact amount is "fill until fluid dribbles out" while the engine runs. .
If you need the refill procedure, let me know.
Old Aug 13, 2021 | 10:38 PM
Speedagent's Avatar
Thank you.
SA
Old Aug 14, 2021 | 12:42 AM
Cee Jay's Avatar
Well, fine then.
Old Aug 14, 2021 | 03:39 PM
George05's Avatar
Old Aug 17, 2021 | 11:46 AM
Attached below is the fluid change process from ZF.
This is the process from ZF, done on a BMW. The transmission and process are the same for Jag.
Old Aug 17, 2021 | 03:11 PM
Speedagent's Avatar
https://www.youtube.com/watch?v=ZRrg...l=ZFServicesNA
Thanks, I've seen this posted previously when I was searching for my info. I've also watched it, good info on this service. Thanks again.
mrtwill
Aug 4, 2016 09:38 AM
LowellLamb
May 28, 2016 03:56 AM
TreVoRTasmin
Apr 4, 2016 02:19 PM
RobinGa
Mar 10, 2016 02:00 PM
NoPaint
Dec 18, 2008 08:56 AM
