Bluetooth module location
Old Jan 26, 2018 | 11:17 PM
dsd's Avatar
dsd
Default Bluetooth module location
All,
New to me 2007 Xk Convertible:
I think my Bluetooth module may be dead (it just sits in the press yes to pair screen).
I知 getting a new battery shortly, but want to check the module out. Any idea where it is physically?
Old Jan 27, 2018 | 01:14 AM
Cambo's Avatar
Under the navigation DVD drive
Old Jan 27, 2018 | 05:29 AM
old_dawg's Avatar
You will find it when you replace the battery. If it's finding the phone but getting hung at the point of trying to pair with the phone maybe you can by with just a hard reboot. Either way suggest you start watching for replacement on EBay. See this thread with it's link to yet another.
https://www.jaguarforums.com/forum/x...module-188065/
Old Jan 27, 2018 | 06:11 AM
dsd's Avatar
dsd
Thanks all.
It looks like it never advertises itself via Bluetooth (no TX) so I bet it’s toast
The ebay watch for a newer module begins.
Old Jan 28, 2018 | 08:31 AM
myexcursion's Avatar
Funny b/c after replacing my battery and doing the typical resets ( window, parking brake Etc ) I figured o would try phone. It actually got past the ops freezing and actually saw the iPhone and got to the pairing section with a 4 digit code - never saw that before. It failed though after entering the code on the iPhone couldn't get the XK phone screen to get past where it used to always freeze at the ' yes or retry/cancel ' screen ...
Old Jan 28, 2018 | 09:23 AM
Sean W's Avatar
Try changing the time out setting on your touch screen. THat's one way to solve. The typical problem isn't that the BT module is "dead". It's out dated. Phones are constantly changing, The BT module doesn't.
Here's a read for you. I swapped my BT module out for an 09 and no problems since. That said, they aren't readily available on eBay so you have to keep an eye out. When they do show up, the asking price is most times astronomical.
Cambo, who responded in this thread offers a service to update the firmware in your BT Module. I would reach out to him as I would think that's your issue. See post #40 in the attached.
https://www.jaguarforums.com/forum/x...riment-152498/
Old Jan 28, 2018 | 01:01 PM
dsd's Avatar
dsd
After I charged the battery, I pulled the grnd for s few to reset the modules. I also reseat the BT module connections.
I was able to successfully pair my phone (iPhone 7+) without issue.
Old Jan 28, 2018 | 02:53 PM
That's great news !!! I may try to unplug/plug the BT module and see if it gets to the pairing code screen. Otherwise disconnect battery too - but not sure if disconnecting battery also resets the car's shifting and I also need to then drive the car for 10+ miles for it to 'relearn' shift patterns Etc....
Old Jan 28, 2018 | 03:02 PM
dsd's Avatar
dsd
I just pulled the black GRND. I think to reset the shifting you need to pull both and touch them. Thus, I suspect you will be fine.
I did have the battery on the Ctek all night until it went green, then pulled it and redid the module connections.
Best of luck!
Old Mar 7, 2018 | 02:55 PM
Whoismootoo's Avatar
this may sound dumb but it has worked for me (using Galaxy S5, S6, S7, and currently S8+) when I lock the car with the button on the door the Bluetooth unit seems to stay awake and time out (need to lock with keyfob and let sit overnight and it goes back to normal). but if you lock it with the keyfob, then unlock & start its available and auto pairs every time.
since I have the remote top module now (installed 1/29/18), I forget more often to use the key to lock and i find myself back in that situation. hope this helps
Old Dec 17, 2019 | 04:19 PM
THollingsworth's Avatar
Thumbs up
So I haven't been trolling the forums for an age, but here in 2019, I finally got irritated enough to track this issue back, and changing the time out on the touch screen resolved the issue!! THANK YOU!!!
Old Jan 25, 2023 | 07:57 PM
Diwoman's Avatar
Talking Dead Bluetooth & Pairing/2009 XF
Just went through the nightmare of figuring out the dead bluetooth. Dealer tried all the various things...said it was dead. I located a replacement, which wasn't easy. Here are the details I can share:
Bluetooth module is under the driver's seat on a 2009. Not sure about other years or models.
It's not the module that's attached to the seat itself. It's under the carpet.
Old MODULE part # is 7G9N-10D893-AF. The replacement module is almost identical: 7G9N-10D893-AG.
Finding that number was hard, but I verified it, first with a Jaguar Dealer, and then with the seller on Ebay.
I paid $205 with shipping. I spent $180 to put it in. If I had felt confident I could tilt the seat back and do it myself, I would have, but it wasn't easy. It's hard to reach and the bolts are difficult to take out because of placement. But, if you're handy that way, go for it...wasn't that hard. Jaguar doesn't make it easy!
Once it was in, and the battery was reconnected, you'll want to start the car, go to the bluetooth setting (mine is iPhone 11). I also deleted all previous phones that were docked. It finally found my phone and asked for me to plug in a 4 digit number, and VOILA! It paired!! I'm more than thrilled because the dealer wanted $850 to do the job.
Old Jan 26, 2023 | 03:59 PM
Hockey_Steve's Avatar
Default BT Module
Thanks all.
It looks like it never advertises itself via Bluetooth (no TX) so I bet it痴 toast
We had the same issue with our XK last year. The selling dealer was supposed to replace the module, but after a frustrating wait I posted this thread and got help from Bill in post #7.
I purchased a Volvo module on Ebay and we have enjoyed uninterrupted BT ever since.
Good hunting
Ubad2
Feb 18, 2018 11:01 AM
rothe
Dec 6, 2010 07:55 PM
rothe
Audio/Visual Electronics
Dec 5, 2010 03:38 PM
jya
Oct 15, 2010 01:01 AM
hlgeorge
May 5, 2010 08:29 PM
