cd changer problems after battery change
Old Jun 16, 2014 | 12:01 PM
bobdr1's Avatar
Default cd changer problems after battery change
Battery on 2010 xk finally died after not being used for a week. replaced it with duracell agm, all well now but cd changer that has 6 discs in it keeps running like it is trying to find cd. the top says insert cd when you press a number but can't place cd in it. at times it says no discs are present. the rest of the audio system is fine, did not even have to reset radio stations after battery replacement. any help out there? car is still under warranty.
Old Jun 16, 2014 | 12:09 PM
Gato Negro's Avatar
Hey there, this might seem obvious....however manually turn the system off and wait a minute then turn it on this should let the system cycle thru.
Old Jun 16, 2014 | 02:44 PM
bobdr1's Avatar
Yeah I had already tried that prior to posting the thread.
Old Jun 16, 2014 | 04:36 PM
bobdr1's Avatar
I called jag dealer, says he has not heard of this problem before, suggested disconnect battery for 5 min and reconnect to see if this fixes it. I just tried this, did not work.
Old Jun 16, 2014 | 06:32 PM
ralphwg's Avatar
This may sound off the wall, but, why not take out the fuse for the cd changer/radio after shutting down. Then restart without fuse. shut down again and replace fuse. Maybe it will work.
Old Jun 17, 2014 | 07:32 AM
bobdr1's Avatar
where's the fuse and which one is it?
Old Jun 17, 2014 | 10:13 PM
ralphwg's Avatar
Bobdr1 - In the owners manual starting on page 189 I found the following: F14 10A Navigation, Power; F25 !0A DVD Sat radio power. These two fuses are in the fuse box between the rear seats. The other possibility is in the fuse box located in the left footwell it is F5 5A Instrument panel logic. The second number in each of the three fuse listings is for the amperage of the fuse. That is all I could find. NGARAGA (I think that's his handle) has a shop manual maybe !he can find more info for you. Good luck
Old Jun 18, 2014 | 06:22 AM
bobdr1's Avatar
got in the car today and cd changer is working perfectly????????????? I quess it was just pissed I got a new battery. Hopefully it will stay happy now. Thanks for the suggestions.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
alpecsa
Sep 7, 2015 11:55 AM
pnwrs2000
Sep 3, 2015 11:55 AM
