No power!
Sounds like you need you need to give us some specifics like year, model, miles, condition, symptoms, history, etc we're not good at reading minds. Maybe we'll be able to help some once we've got some info
Queen and Country (04-21-2016)
Seems it went into the limp mode as the cat blocked like choking and then got released after some time stopped. Anyway i had to get a new one. Might not be your problem but that was mine.
I got all that info and it turned out one of the cats had gone, it sounds like it went into limp home mode. Mine made it home. Left of for a while then it drove as normal. The engine light then would come on after a short journey.
As per WhiteXKR, there is a grounding post very near the battery that sometimes may have a continuity issue and get very hot due to resistance. That would possibly cause what you describe. His troubleshooting was to check the temp (without using fingers, it gets that hot) of the post. He disconnected his, cleaned everything very well and reinstalled tight. No issues after that.
Received 1,894 Likes
https://www.jaguarforums.com/forum/x...3/#post1394317
bdragomir
04-26-2016 12:17 PM
CoventryFlagship
04-20-2016 05:52 PM
FS[Canada]: Fog Lamp S-Type Used Repaired Working
zigzewel
04-13-2016 10:23 PM
hisport
04-13-2016 09:39 AM
