Does your XK always start up on the first try?
Old Jul 8, 2015 | 04:58 PM
amcdonal86's Avatar
Default Does your XK always start up on the first try?
I've been noticing lately that my XKR does not always start up on the first try. At first, I thought it was because I didn't drive it that often, but now I drive it almost every day (changed offices and lost my company car!). It seems like maybe 1 in 10 starts it does not start up. It will rev up to 1500 or so and then not catch and then just stall immediately. Usually it starts on the second try.
Only once in the last 2 years has it failed to start on the second try--and that was a weird one because the car had been driven 5 hours earlier. It failed to catch several times and then idled very rough and eventually stalled out, and would not restart until I let it rest for a minute or so.
No check engine light has come up, but I have not yet scanned for codes.
Do your XKs always start up???
Old Jul 8, 2015 | 05:33 PM
Cee Jay's Avatar
Yes. Yes it does. Every time.
Old Jul 8, 2015 | 05:56 PM
ralphwg's Avatar
Invariably
Old Jul 8, 2015 | 06:22 PM
mosesbotbol's Avatar
No, it did not, but not often enough to get in front of it.
Old Jul 8, 2015 | 06:28 PM
axr6's Avatar
All 3 of our 5.0 Jags start on the first try. No exceptions.
Old Jul 8, 2015 | 07:19 PM
Chadly's Avatar
Starts every time
Old Jul 8, 2015 | 07:40 PM
Joachim1167's Avatar
No problems here.
Old Jul 8, 2015 | 08:16 PM
kj07xk's Avatar
Only once did it not start on the first shot, but that was probably pilot error on my part, as I had recently gotten the car, and probably let up on the start button or brake too soon.
Old Jul 9, 2015 | 12:49 AM
mcdutch's Avatar
my 2007 xkr, no problems at starting!
Old Jul 9, 2015 | 03:17 AM
Cluffstarr's Avatar
I had this last night. I think I took pressure off the starter button. I'm certainly hoping this was the case...
To the OP, might be worth getting an ECU Scan (or whatever the correct term is) to see if there are any pointers to what the issue is. Hopefully nothing too serious as it seems to always (eventually!) start for you.
Old Jul 9, 2015 | 03:46 AM
1 of 19's Avatar
07 XKR every time.... my 96's not so much...
Old Jul 9, 2015 | 08:25 AM
sherbercars's Avatar
1st time allways.
Old Jul 9, 2015 | 08:42 AM
Jagfixer's Avatar
Have you cleaned the throttle body? Is the battery fresh, not original? Have you use any fuel conditioners, yet?
Old Jul 9, 2015 | 01:13 PM
CleverName's Avatar
I encountered a similar issue back in 2012.
https://www.jaguarforums.com/forum/x...n-light-69497/
It was intermittent, but frequent. When it finally failed in the hands of the dealership, they found both my key fobs defective and replaced them.
No issues since.
Old Jul 10, 2015 | 12:06 PM
Ngarara's Avatar
Always starts
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
