Got some High FLow 200 cell cats installed. Need input
Old Jun 18, 2018 | 08:41 PM
AlexJag's Avatar
Sponsor
Default Got some High FLow 200 cell cats installed. Need input
So I finally decided it was time for more mods and bought some direct fit 200 cell high flow cats , installed right before a drag racing event.
results : inconclusive
noise : way up at WOT
power: appears to be down compared to stock , trap speed was down compared to runs with stock cats. Butt feeling also telling me car is down on power
Adjusted for the extra flow in the tune with not much improvement
Now I have not replaced the midsection yet and its all stock, but dont think leaving it stock is making things slower compared to stock can it?
I did a temperature test with the infrared thermometer and test shows 100 degree difference between the front and the back. Front is hotter, which tells me by all internet searches that catalytics are bad and restrictive, but Im not sure if this test applies to high flow cats? Can you guys with high flow cats verify this is normal please?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Jun 18, 2018 | 09:28 PM
tberg's Avatar
How did you get CA certified 200 cell cats in San Diego. I'm replacing mine this week and could not find any after market cats for my 5.0L car anywhere.
Old Jun 18, 2018 | 09:40 PM
Stuart S's Avatar
... deleted
Old Jun 18, 2018 | 09:45 PM
AlexJag's Avatar
Sponsor
You cant get legal aftermarket ones
__________________
Old Jun 18, 2018 | 10:32 PM
tberg's Avatar
Thanks, that's what I thought. I got tired of getting CEL warnings about once per month referring to my CATS as the problem, so I decided to bite the bullet (and it's a very big bullet), and purchase new ones from the dealer.
Old Jun 18, 2018 | 11:29 PM
AlexJag's Avatar
Sponsor
Isn't oem warranty for the cats like 100k mi and 8 years?
__________________
Old Jun 19, 2018 | 09:11 AM
tberg's Avatar
Yes, but I have about 150,000 miles and the car is over 8 years old.
Old Jun 19, 2018 | 12:08 PM
Ranchero50's Avatar
Cats out of a late model Mustang will weld right in. Mine acted similar, loud and slow with 200 cell cats. Mostly too loud. Picked up a set of take off's form a 2010 or so and welded them in place. Flow well enough and the noise level dropped back to realistic.
Old Jun 19, 2018 | 12:19 PM
mosesbotbol's Avatar
This is a good thread and important subject as many will be in this position where decats or 200 cell you'd think be the way for more power vs staying with oem.
Old Jun 19, 2018 | 08:18 PM
jahummer's Avatar
That is very strange, I lost no power with mine. A forced induction motor is an air pump, open the front end, open up the back end, adjust VE, etc. in the map and you should have much more power with increased flow and air volume.
Old Jun 19, 2018 | 10:24 PM
AlexJag's Avatar
Sponsor
I agree . The only way I would loose power from the cats is if they are more restricted . So I'm trying to see if it's in the tune or the cats
Old Jun 20, 2018 | 06:51 AM
Originally Posted by AlexJag
I agree . The only way I would loose power from the cats is if they are more restricted . So I'm trying from see if it's in the tune or the cats
I put free flowing mufflers on my XK and lost a lot of power, especially down low. I couldn't wait to remove them (reverting to stock) and ended throwing them in the trash...
Old Jun 20, 2018 | 09:49 PM
jahummer's Avatar
There is a difference between a forced induction motor and a NA one, you may have lost some of the necessary back pressure or unbalanced the VE.
Old Jun 21, 2018 | 01:07 AM
steve_k_xk's Avatar
I'd say unbalanced the VE
13.72 is the best time i have run in an n/a xk which has 100cell cats and tune to suit
also in terms of the xkr by memory cambo ran 13.18 in stock form then 12.8X with 400 cells / x pipe and adjusted tune allowing for more back pressure
Old Jun 21, 2018 | 06:33 AM
What is "VE"?
Old Jun 21, 2018 | 08:33 AM
Ranchero50's Avatar
Exclamation
What is "VE"?
Volumetric Efficiency...
VE maps are the curse of modern OBDii processors. The original electronic fuel injection monitored the engine rpm, throttle setting, manifold pressure (MAP) and a temperature or two and determined what fuel dose to apply to the engine based on Speed / Density (S/D) maps which were coded for stock engine component air flow. Throw in a set of heads or different cam which lowered the MAP and the engine had problems due to trying to run richer for the lower MAP. Later EFI engines used mass air meters which could care less what mechanical components were in the engine (within limits) and coded based on air flow. They are what really uncorked performance limits in the early '90's. OBDii is a much more stringent program due to government meddling and like S/D systems it will code or just not perform if the actual performance doesn't match the 'assumed' performance. To me it really was a step backwards for the home grown builder.
Old Jun 21, 2018 | 10:25 AM
Brutal's Avatar
8/80K
Old Jun 21, 2018 | 02:55 PM
Rey's Avatar
Rey
This is elementary, but did you do a "hard reset" after installation?
Check engine light on? If not, it is some indication that the cats are prperly working correct fuel ratio mixture to the politically correct level.
Old Jun 22, 2018 | 05:41 PM
AlexJag's Avatar
Sponsor
Not just a reset but ecu reprogramming as well to account for lower back pressure...
Now Check engine light occasionally comes on for cats inefficiency , bu this is expected for high flow cats.
Now can anyone with high flow please confirm if the temperature test is still valid fo high flows cats or is it supposed to be reversed as in my case where inlet is 100 degrees higher than outlet?
__________________
Stuart@VelocityAP
Jul 9, 2021 02:18 PM
abs777
Feb 10, 2017 02:29 PM
Maxville
Jun 27, 2014 12:40 AM
jag79
Oct 14, 2010 05:44 AM
rocklandjag
Sep 24, 2010 10:07 AM
