Headlamp Washers Not Working
Old Apr 16, 2018 | 01:59 PM
Tango Nevada's Avatar
Default Headlamp Washers Not Working
Good evening everybody (it's evening here...
The headlamp washers are not working in my '07 X150 (18K miles). The pump runs perfectly on the bench, but not on the car.
I'm wondering where to start fiddling with it first. Is there by any chance a relay, in the Power Distribution Box, which is the last component in the circuit before the pump itself? If so, can anyone tell me how to get at said Power Distribution Box? I can't find it in the Workshop Manual...
Old Apr 16, 2018 | 02:38 PM
Sean W's Avatar
There is a powerwash relay in the FSJB power distribution R11. Fuse F04 (30A) FSJB is in the engine bay rear corner on your model. If you open the bonnet, it should be near the bonnet release up near the firewall.
Attached Thumbnails Headlamp Washers Not Working-screen-shot-2018-04-16-2.44.02-pm.png
Old Apr 16, 2018 | 02:44 PM
That's great information, thank you. Do you know how I get to the FSJB, where it is located in the car?
Old Apr 16, 2018 | 02:45 PM
Sean W's Avatar
Just added an attachment to my initial post
Old Apr 16, 2018 | 02:49 PM
Sean W's Avatar
How are you at reading wiring diagrams?
Download it here (free)
http://www.jagrepair.com/images/Auto...79toB09096.pdf
Search "powerwash" and you should see it.
Old Apr 16, 2018 | 03:09 PM
I'm a spannerman, not an electrician, but I can usually manage, and I think you've given me all I need - for now at least.
One question, though. My screen washers work perfectly; I presume/hope they take power from a different relay?
Old Apr 16, 2018 | 03:21 PM
Ranchero50's Avatar
The lamp washers only fire every five or so squirts on the windshield. Just a FYI.
Old Apr 16, 2018 | 03:48 PM
I don't even get the initial squirt when I try to use them the first time. I'm hoping it's just the fuse or relay...
OK, I reckon can find the Power Distribution Box, and Fuse 04, no problem. Is it apparent which is the headlamp washer relay once I get in there?
Old Apr 16, 2018 | 04:56 PM
Sean W's Avatar
They should have the relay named (probably abbreviated) and the relay number. I believe the relay numbers are embossed on the box but not 100% certain. Sorry, I've never been in my FSJB and I've never found a relay schematic, just the fuse schematic.
http://www.jaghelp.com/2015/02/jagua...on-and-id.html
rkindon
May 6, 2014 02:45 PM
flyrr100
Nov 17, 2012 04:35 PM
04XJwpg
Feb 18, 2012 12:21 PM
andriy
Jun 8, 2011 02:31 AM
hardmat
Dec 12, 2010 02:30 PM
