I need help with Instructions for hard reset.
Old Jul 8, 2021 | 05:56 AM
Baxter3319's Avatar
Default I need help with Instructions for hard reset.
I am hoping someone can post the instructions for a hard reset for a 2007 XK.
THANK YOU IN ADVANCE.
Old Jul 8, 2021 | 10:25 AM
Cee Jay's Avatar
Remove both battery cables from the battery. Touch the cables together for several seconds being completely assured that neither cable touches the battery posts! Cover the battery top with a non-metallic shield if you feel uncomfortable. Reinstall the cables from where you removed them. Reset the window operation.
That is all.
It's really very easy, just make sure the battery is totally out of the circuit.
Old Jul 8, 2021 | 12:04 PM
JagV8's Avatar
It will reset all the OBD monitors (used for smog test) so be sure you're OK with that!!
Old Jul 8, 2021 | 06:05 PM
guy's Avatar
guy
May I inquire as to ‘why’ you need to perform the reset?
Old Jul 9, 2021 | 05:26 AM
+1
There's a limit to what a HARD RESET does. If you are hoping to clear a warning or error code, it is unlikely to help.
Old Jul 9, 2021 | 07:01 PM
Speedmaster's Avatar
I have gotten quite good at the hard reset. I have to do it every time...and I do mean EVERY STINKING TIME I clear the codes...because...the car won't start.
Surely there is an independent mechanic in Chicago that will take my car and do some sorcery to it. I just have to find them.
Old Jul 9, 2021 | 07:56 PM
Cee Jay's Avatar
Your car is toast. You now have to get rid of it as it will never work right.
I will give you $5k for it, right now.
Old Jul 9, 2021 | 09:24 PM
Tempting as that is, I will take that under advisement, Cee Jay.
I drove to work today and man was it a glorious cruise. Love downshifting while driving through various under-bridges.
Old Jul 9, 2021 | 10:38 PM
ralphwg's Avatar
Talk to Warren Preis at European and U. S. Car Service 773-248-1200 4080 N Broadway. He was the Service Manager at Orloff many years ago. If he can't help you perhaps he can steer you in the right direction. When I lived in Chicago he serviced all my cars once they were off warranty.
Old Jul 10, 2021 | 04:18 AM
JagV8's Avatar
Horrors. And unique, I think
Without doing a hard reset, when you try to start does it crank?
Any flagged OBD codes?
What pending OBD codes?
Old Jul 10, 2021 | 06:57 AM
I will report out on this later this morning on exact codes...I guess I could just post the entire report.
To your first question, after I reset (erase) the codes using Autel AP200 and turn the car off...when I go to try and restart the Start/Stop button will not light up/engage. Some lights will flicker (warning, I forget which ones but one is to lower and to the right of the round fan dial on the infotainment) and a loud series of clicks from the relays occur.
Will try and replicate and respond later. Thanks for asking.
Old Jul 10, 2021 | 07:08 AM
guy's Avatar
guy
I would think this the obvious question: Why continue to use the ODBII tool that is clearly incompatible with this system? Why gamble on the car being absolutely bricked? Please don’t misinterpret me… I wish you all the luck and success. And I do hope a dire situation does not fall upon you.
Old Jul 10, 2021 | 07:12 AM
It is a good question, but I am not convinced the tool is the fault...and really, I am going to figure this out one way or another. So, if indeed it bricks it, it will be at the shop shortly thereafter for formal testing.
Old Jul 10, 2021 | 10:09 AM
Sean W's Avatar
Here's the specific procedure from the Advanced Diagnostics manual:
JacksonvilleJag
Mar 8, 2024 05:12 AM
Jomiltom
May 17, 2019 03:22 PM
mick99
Sep 7, 2016 09:38 AM
Richxk8
Aug 15, 2016 10:49 AM
pdog2000
Feb 1, 2012 10:39 AM
