paddle shifters extender
Old Sep 27, 2019 | 10:03 AM
yidal8's Avatar
Default paddle shifters extender
Under some situations I wish those paddles were longer, specially on the XKR. Anything nicely designed available for a Jaguar?
Same smallish paddles are on my XJ, and previous XFs.
Oops, just saw a previous thread on this subject here https://www.jaguarforums.com/forum/x...nsions-192624/
Old Sep 27, 2019 | 08:03 PM
Stuart S's Avatar
That was my thread. The link in my Post #1 no longer works, so you'll have to search elsewhere for similar paddle extensions.
Old Sep 27, 2019 | 10:08 PM
badicedog's Avatar
Arden sells a set of brushed aluminum paddles. Warning, they are not cheap.
Old Sep 28, 2019 | 07:01 AM
yidal8's Avatar
Ordered these for $32, see how they work.
Old Sep 28, 2019 | 08:24 AM
Stuart S's Avatar
They appear to be exactly the same as mine, in the above picture in my Post #2.
Old Sep 28, 2019 | 09:56 AM
DGL's Avatar
DGL
My first mod was a set of aluminum Jaguar paddle shifters. They feel good and are extended compared to the stock plastic ones. IMO a perfect size.
Old Sep 28, 2019 | 10:27 AM
Cee Jay's Avatar
I rubber-banded some large popsicle sticks on mine..... worked OK until they slipped off.
Old Sep 28, 2019 | 02:39 PM
DGL's Avatar
DGL
You're a genius! Did you paint them black or leave natural with saliva still on them?
Old Sep 28, 2019 | 02:42 PM
Cee Jay's Avatar
Drooled-on wood. I really did this, just to see if I thought any improvement may be had for the real things. I found out that I use the center of the paddles anyway, and the extension would be merely cosmetic and not worth the effort in MY case.
Old Oct 7, 2019 | 02:21 PM
TraxtarXKR's Avatar
A warning to those looking at these stick-on paddle extenders... they will put your paddles VERY close to the wiper and signal stalks.. to the point that your hands cannot fit between them. If your driving style is to have your hands on the paddles at all times, you will need to adjust it so that you only touch the paddles when you shift... and have to be careful when paddle shifting during a turn or risk turning on/off wipers or turn signals.
Old Oct 7, 2019 | 06:02 PM
ralphwg's Avatar
I was going to try the used Popsicle sticks but decided they would be too sticky. So I went with Stuarts extenders and bent them a little in a vise to enlarge tthe distance between the built in stalks and they work fine for me.
Old Oct 11, 2019 | 10:39 PM
CleverName's Avatar
This was part of the problem I encountered... That and the fact the top portion also stuck out far enough to hit my leg as I turned the wheel. So I sawed a slot in the thickness right above mount, and bent the upper part of the lever parallel to the steering wheel.
Soooo much better.......................
Old Oct 12, 2019 | 06:25 AM
pwpacp's Avatar
Clever, can you post a pix or two for us?
Old Oct 12, 2019 | 02:00 PM
CleverName's Avatar
Old Oct 12, 2019 | 03:39 PM
pwpacp's Avatar
That looks like a much more natural angle. That'll be another winter project for me this year. Thanks!
Old Oct 12, 2019 | 04:02 PM
CleverName's Avatar
It certainly feels better, and gives your fingers room between it and the control stocks. I've really come to love them now.
They are a bitch to bend, even with the cut slots, but with a vice, a block of wood and a big-bigger-biggest hammer, things slowly begin to move!
Old Oct 15, 2019 | 07:00 AM
yidal8's Avatar
So I received and installed the extensions as is. So far I like them, and for me, they are not too close to the stalks, except at a certain turning position of the steering wheel which is not a big deal for me. Certainly it will take time to fully get used to them. I do wish the edges were more rounded though.
Maybe_XJ
Jun 25, 2024 07:55 AM
yidal8
Aug 29, 2019 04:09 PM
Ceckman
Apr 7, 2017 01:31 PM
HavocX10
Jan 12, 2016 01:42 AM
SrJaguar
Jan 20, 2015 11:42 AM
